Old 04-26-2018, 08:52 AM   #1
Andy’97
Andy’97 is an unknown quantity at this point
Fuel Sending Unit Issue - Please Help!
I have an issue that I'm hoping someone on here has the expertise and experience to offer some suggestions. I've purchased a '97 240sx that has sat for quite a while. I pulled the fuel tank and have a clean replacement ready to install. I have a new fuel pump but not sure how to handle the sending unit as the original one from the car is destroyed and the replacement tank is from a '95 so the sending unit is a 3-prong harness and not the 4-prong used in '96-'98 240's with the addition of the fuel temperature sensor. This thread has great photos showing the difference in the '95 sending unit and the '96+ sending unit:
http://zilvia.net/f/showthread.php?t=643937
I cannot find a '96+ sending unit to use. I could use some guidance on whether a 3-prong sending unit (one without the fuel temp sensor) would be ok to use with a harness converter to connect to the 4-prong coming from the '97 chassis. I want to get this sorted before installing the fuel tank and rear subframe since these are not fun things to have to pull down every weekend. Thank you all, I really appreciate the help on this one!
-Andy
Andy’97 is offline   Reply With Quote
