Old 10-31-2004, 09:05 AM   #1
jedc
jedc is an unknown quantity at this point
Send a message via AIM to jedc
KA New questions involved in auto to manual
I bought a '98 ka that was an auto for my '93 240sx with blown motor. On the back of the crank where the flywheel bolts up, there is a hole with some type of brass fitting in it on my old motor. The new motor has the hole but no fitting. Anyone know what this is and if I'll need it? Also my new motor didn't have an alignment peg where the bellhousing bolts up at the top. Will I need that either?
jedc is offline   Reply With Quote
Old 10-31-2004, 09:12 AM   #2
Phlip
Yes, I look like that
Phlip's Avatar
I understand that there is a different bearing/bushing or whatever the fuck it is called on the rear of an auto engine, compared to a 5-speed one... I was lucky enough to have gotten an engine that was initially 5-speed for my engine/driveline swap so this wasn't a question I had to ask exactly.
Weirdo
And I write too!
Old 10-31-2004, 10:17 AM   #3
240dreamer
240dreamer's Avatar
240dreamer will become famous soon enough240dreamer will become famous soon enough240dreamer will become famous soon enough
That little brass fitting is the pilot bearing. Yes you need it.
89 240sx Hatch
06 Honda CBR600 F4i
240dreamer is offline   Reply With Quote
Old 10-31-2004, 10:59 AM   #4
Phlip
Phlip's Avatar
^^^ Oh shit, now I feel like a DUMBass, PILOT BUSHING!!! Yeah you need it, in fact you need to go down to nissan and give them 10 bucks for a new one, as you should everytime you remove/change the clutch.
Weirdo
And I write too!
Old 10-31-2004, 11:56 AM   #5
jedc
Thanks a lot guys. What should I do about the alignment stud, try and yank the other one out or get a new one? Anyone ever had to do this?
Old 10-31-2004, 05:07 PM   #6
Phlip
Phlip's Avatar
If you are getting another clutch kit, it should also include a clutch alignment tool, and if you aren't, another one shouldn't be terribly expensive.
Weirdo
And I write too!
Old 10-31-2004, 07:45 PM   #7
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
I think he means the alignment stud for the flywheel...it's pressed into the crank.
You'll need to get a new one.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 10-31-2004, 07:48 PM   #8
Phlip
Phlip's Avatar
- Brian
Cool, and in such case, that would be the "thing" that I was speaking of earlier, different from the auto to 5-speed.
Weirdo
And I write too!
Old 10-31-2004, 08:20 PM   #9
jedc
The alignment "stud" I was talking about is what would align the top part of the bellhousing on the back of the engine. Also, I think what I am looking for is the alignment stud for the crank. It's pressed into a small hole in between some of the bolt holes for the flywheel bolts. Can anyone confirm? I tried pulling them out of the other motor after applying some loosening fluid and they didn't wanna come out.
Old 11-01-2004, 01:06 AM   #10
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
the pilot bushing sometimes comes with clutch kits...
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-01-2004, 04:41 AM   #11
Phlip
Phlip's Avatar
"Pulling out" a pilot bushing is nearly fuggin impossible, I have never seen it done... On anything. It's brass, break it out of there and put the new one in.
Weirdo
And I write too!
Old 11-01-2004, 08:02 AM   #12
crioten
"buddy jesus"
crioten's Avatar
thats why they have slide hammers, i got mine out
autozone rents them
Old 11-01-2004, 09:28 PM   #13
jedc
Yes guys, I am replacing the pilot bearing tomorrow as it came with my clutch kit. I will be renting a slide hammer to do it. Also, I need to know if the alignment stud is really necessary. I read that it is there so you put the flywheel on the correct way. Is there anyway to pull it out of the other motor if I need it?
Old 11-01-2004, 09:49 PM   #14
orion::S14
orion::S14's Avatar
Alignment pin for the flywheel is not "necessary"...
If you don't use it, just line the flywheel up with the hole in the crank where the pin should be.
- Brian
