Old 11-03-2004, 07:07 PM   #1
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
S13 - Lower control arm bushing sleeve seized.
I dont know how this happened but it happend to my passanger side lower control arm.
Problem:
Lower controll arm bushing has a metal sleeve so the bolt can go through it, the sleeve seized to the bolt. so the bolt wont come out!!! the nuts off bolt.
Tried to:
Impact it out, try to rotate it with huge breaker bar, but the bushing moves.
Tryed torching it, heated the control arm. heated bolt to see i could get it to crack or losen.
wd-40'd also.
Hammered the piss out of it.. still wont go through.
Also the Head of the bolt, wont let a screw driver or anything between it and the crossmember, i tried hammering one into it.. but no luck.
What do I do to get this out? I dont have an extra cross member so i cant remove it.
@woooster on instagram
kuruptR is offline   Reply With Quote
