![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Tranny Main Seal ????'s
Is the main seal on an SR the same as in a KA trasmission?? if not is there any other seal from another car i could use??
thanx S13Dan
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
![]() Join Date: Jul 2001
if you mean the seal at the end of the tranny, where the driveshaft slides in, yes they are the same.
www.enjukuracing.com |
Yes the seal where the tranny meets the drive shaft.(is that the main seal?) Was it very difficult to change? i hope not. i havnt had a chance to get under the car and look.
#5 |
It is very easy to replace.
-Remove the 4 bolts where the driveshaft meets the differential -Slide the driveshaft out of the transmission -Pull the old seal using a seal puller or suitable tool -Tap the new seal in (I believe you should lubricate the inside of the seal w/ silicone lube, not sure about that one) -Install driveshaft in reverse order.
'93 240sx Coupe SR20DET Blacktop ![]() |
