Old 08-01-2019, 04:17 PM   #1
K_never_broke_again
K_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura about
s14 Question about 95 s14 wiring
So i bought an s14 in october planning to sr swap it, but after pulling the engine and harness out i’ve run into what appears to be a pretty big problem. i was watching all these vids on how to remove the original harness, but i was hella confused because it seemed like nobody had the same wiring as me when i realized... i have a 95, meaning the harness is different than any other year 240. as opposed to the standard ecu and dash plugs, i have like 3 additional plugs that also connect near the ecu plug. there is a blue plug with 2 or 3 wires going to it, a small white plug, and a larger plug located behind the ecu, which you have to pull a lever down to take off. my s13 sr20det harness which i thought would work obviously doesn’t have any of these other plugs. so my question is how am i going to wire it up? i can’t be sure but it also seems like none of the sr plugs will connect to the parts of the ka harness that it needs to. do i need to buy a whole new harness, or can i just ghetto rig it up? i’m only 17 and this is my first swap ever, so any advice would help. i added a url which is a pic of the plugs i’m talking about, they’re in the middle near the ecu connector
https://images.app.goo.gl/pmmi4R7A63D7UTo28
Last edited by K_never_broke_again; 08-02-2019 at 12:24 AM.. Reason: “we need more information to better help you”
K_never_broke_again is offline   Reply With Quote
Old 08-01-2019, 04:32 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Originally Posted by K_never_broke_again View Post
i have like 3 additional plugs that also connect down there. my sr20det harness which i thought would work obviously doesn’t have any of these other plugs.
3 additional plugs WHERE? Under the hood? Under the dash? Are you using an s13 sr20 or s14/15? Do you have the oem engine wiring harness or an aftermarket one? Do you have a copy of the FSM for that year car?
we need more information in order to better help you
240sx, engine bay harness, ka24de, s14, sr20det
