Old 11-20-2004, 03:17 PM   #1
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
Whine when i drive past 30 and decelerate...
The rear of my car whines a lot louder than before... started hapening last monday. Usually the loudest when i drive on the freeway, and decelerate from it... i think when i slow down to 25-30 miles u cant hear it anymore..
Let me know what you think...
VLSD pumpkin needs the fluid changed???
or...
Rear hub/hubs are wearing out???
Davis
[email protected]
Sfourteen
dct223 is offline   Reply With Quote
Old 11-20-2004, 06:02 PM   #2
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
VLSD needs new fluid
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 11-20-2004, 06:03 PM   #3
IvanAtSPRacing
IvanAtSPRacing is an unknown quantity at this point
I would also say its your rear diff. Do you have a leak? I would guess that its probably pretty close to empty.
Ivan
www.PhatKA-T.com
www.sound-performance.com
IvanAtSPRacing is offline   Reply With Quote
Old 11-20-2004, 09:48 PM   #4
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
Or it can be ur throwout or ploit bearing.
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 11-21-2004, 01:06 AM   #5
dct223
dct223's Avatar
I just got my clutch changed.... got a new throw out brearing... not a pilot, mechanic said mine was still good
thanks for the info guys, ill change my fluid proll over thanksgiving break and see how that helps..
Sfourteen
Old 11-21-2004, 09:36 PM   #6
Phoen_x_s14
Phoen_x_s14's Avatar
Phoen_x_s14 is making a name for him/her selfPhoen_x_s14 is making a name for him/her self
I know a S14 that does that too but its also so an automatic. Hmmm maybe a change of the diff. fluid could fix it.
Phoen_x_s14 is offline   Reply With Quote
Old 11-24-2004, 05:07 PM   #7
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
i am having the same problem with my car. change out the fluid and add some lucas stabilizer in there also. That will help quiet down the differential. most likely the noise is just due to low amounts of fluid. try not to drive it too much or to hard while it is making the noise.
l33tmonkeyman is offline   Reply With Quote
Old 11-24-2004, 08:12 PM   #8
ZK
ZK's Avatar
ZK is making a name for him/her selfZK is making a name for him/her selfZK is making a name for him/her self
Do you have an exhaust system or subframe spacers? My car started doing that after I put in subframe spacers. I'm guessing its the extra stiff rear and the noise is coming through the chasis more now because it is stiffer. Its kinda like a vibrating sound.
ZK is offline   Reply With Quote
Old 11-25-2004, 11:25 PM   #9
xizm02
xizm02 is an unknown quantity at this point
Send a message via AIM to xizm02
my car had the same problem also but i didn't think about it to much. today i swaped my tranny out caus it finally blew (145,000) miles and had to take drive shaft out so while i was at it i canged out the yolk on the diff and the fluid. it isn't making that noise ne more. so try changing the diff fluid and if that dosn't work u can get a new yolk right from nissan
xizm02 is offline   Reply With Quote
