Old 01-27-2020, 08:36 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
Air bag light flashing in Stock '95
The airbag light starting flashing a year ago. It started when I started the car and I heard a click click noise when it happened. Was also having hesitation while this click noise would occur. That click noise fortnately has been figured out. The fuel pump relay was cutting out because the ground from battery to engine was corroded and has now been replaced and all grounds on engine harness have been cleaned. Engine no longer cuts out.
Fuel pump relay works fine now but air bag light still flashes and flashes continuously. I did the reset and it is now flashing much slower with a 1 then 2 flash and starts over. I assume it's now giving a code. I guess it could just be a coincidence that the problem started with the battery ground cable issue or could it have damaged the module. Any idea's
Thanks
z32 front brakes, spl tc rods
95se is offline   Reply With Quote
Old 01-27-2020, 08:51 PM   #2
Agamemnon
Agamemnon's Avatar
Have you downloaded the FSM and looked under the BF section? I would assume you have because you've been here since 2002.
You have #2 SRS fault.
Old 01-27-2020, 08:55 PM   #3
95se
95se's Avatar
Yes I looked at it. Will look again.
Thanks
Old 01-28-2020, 10:54 AM   #4
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
Page BF-98 to BF-100
Sfourteen
dct223 is offline   Reply With Quote
