Old 02-25-2020, 11:14 AM   #1
NashT
NashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choices
A/C Fan Question
Hey guys, im wondering if I should keep the ac fan in as an auxiliary fan to help cool down the system
No im not asking how to wire it, I deleted the ac system, evap, and egr.
I just put a new fan clutch and the GKtech fan on.
Basically im just wondering if the belt fan will be enough, just seems like a huge gap to pull air without the assist ac fan.
Ive read some conflicting stuff about the ac fan, it only works when ac is on, or it come come on at idle with high temps even without ac on. Seems like some people have had the same idea to keep it as an additional fan which is what im leaning towards.
Is it worth wiring up to the AC button switch as the activator, or should I just pull it and run the clutch fan? Yes running stock shroud.
Anyways, i get this is essentially a dumb question, im most likely just overthinking it. But i could see using that ac fan as an auxiliary as a plus for drifting to help cool down the system even more.
NashT is offline   Reply With Quote
