Old 07-06-2020, 08:17 AM   #1
MadTyteJDM
MadTyteJDM is an unknown quantity at this point
1991 Nissan Silvia S13 K's Club, sold
I personally owned and drove the vehicle in Japan while I lived in Japan and had it imported it in October 2018 under the 25 year rule through Ronin Imports. I had no problems getting a MD title for it with historic registration and Geico car insurance. It is a 5 speed turbocharged RWD RHD car with 68k miles. The car was completely stock when I bought it and I had a tuning shop in Japan perform all the modifications:
Engine:
Built by Black Mamba Car Make Shop
350 WHP Dyno Tuning at STF High Quality Tuning Shop
Apexi Power FC with EL Commander and Datalogit
Apexi Power Intake Dual Funnel Air Cleaner
Apexi Exhaust Control Valve
AEM UEGO Wideband Air/Fuel Ratio Gauge in Ash Tray
Tomei Arms 7960 Turbo Kit @ 1.2kg/cm2 (17psi)
Tomei 1.2mm Metal Head Gasket
Tomei Rocker Arm Stoppers
Tomei 740cc Side Feed Injectors
Tomei Poncams 256* IN/EX, 11.5Lift
Tomei Expreme Exhaust Manifold
Tomei Expreme Turbo Outlet Pipe
Tomei Metal Ornament Plate
Tomei Fuel Pressure Regulator Type S w/ Tomei Gauge
ISR Stainless Steel Front Pipe
SARD High Flow Catalytic Converter
HKS Hi Power Stainless Steel Exhaust
HKS SSQV4 Super Sequential Blow Off Valve
HKS EVC6-IR Electronic Boost Controller
HKS Turbo Timer
ISR Front Mount Intercooler and Intercooler Piping Kit
ISR Aluminum Radiator and Silicone Radiator Hoses
ISR Lightweight Pulleys
Greddy Racing Iridium Spark Plugs
Z32 MAF with Wire Harness Plug
Z32 Fuel Filter
New OEM S13 Gas Tank
New OEM S13 Water Pump
Walboro 255L/HR Fuel Pump
Nismo Fuel Cap
Nismo Radiator Cap
Nismo Oil Cap
Nismo Engine Plate Sticker
Circuit Sports Aluminum Coolant Reserve Tank
Circuit Sports Oil Filter Relocation Kit
Nismo Oil Filter w/ Mobil1 10W30 Synthetic Oil
GKTech Radiator Cooling Fan
GKTech Oil Catch Can
Suspension:
Laser Alignment Work by Lexon Exclusive in Japan
TEIN Street Flex Coilover Kit
Ikeya Formula Roll Center Adjuster Pillow Lower Arm Kit
Ikeya Formula Pillow Tension Rod
Ikeya Formula Adjuster Rear Lower Arm Kit
Ikeya Formula Rear Toe Adjust Rod
Ikeya Formula Traction Adjuster Rod
Ikeya Formula Rear Camber Adjuster Upper Arm
ISR Gold Sway Bars with Bushings (Front/Rear)
Nismo Front Power Brace II
Wheels:
R33 GTR Wheels Painted KH2 Gunmetal Gray
Federal 595 Super Steel Tires (215/45/17)
Rays Engineering Lug Nuts and Valve Stem Caps
ISR 5 Lug Conversion Kit (Front/Rear)
Brakes:
Z32 Front Brake Calipers Painted KH2
Hawk HPS Brake Pads (Front/Rear)
P2M Slotted and Drilled Rotors (Front/Rear)
ISR Stainless Steel Brake Lines (Front/Rear)
Transmission:
Competition Stage 2 White Bunny Clutch
Competition Stage 2 White Bunny Flywheel
ISR Stainless Steel Clutch Line
Nismo Engine & Transmission Mounts
ATS/Carbonetics 1.5 Way LSD
Redline 75W90 Rear Differential Fluid
Redline MT90 Transmission Fluid
Interior:
BRIDE EUROSTAR II Seats w/ Gradation Logo BE BRIDE Seat Covers (x2)
BRIDE Super Seat Rail MO Type
BRIDE Sport Interior Rear Seat w/ Gradation Logo FA (Done by BRIDE Japan)
Momo Race Steering Wheel
Works Bell Slim Steering Wheel Boss
Works Bell Quick Rapfix Release Hub
Works Bell Quick Rapix Release Lock
Nismo Duracon Shift Knob
Custom Checkered Floor Mats
Broadway Rear View Mirror
Juran E-Brake Drift Button
Custom Fold Out Cup Holders in Doors
Custom Nissan Silvia Key with Nismo Keychain
Exterior:
S13 Front Aero Bumper
S13 Vertex Side Skirts
S13 Rear Aero Spats
S13 CA18DET Rear Spoiler
HICUSA Side Window Visors
HICUSA Rear Window Visor
D-Max Clear Corner Lights
D-Max LED Tail Lights
S13 Triple Projector Headlights
DDM Tuning Ultra 5500K HID Kit
Nismo USA Spec Metal License Plate Frames (Front/Rear)
30% Tinted Windows
KH2 Painted Engine Bay by Black Mamba Car Make Shop
Mild Engine Wiring Tuck and Shaved Stock Intake Bracket
Fender Wire Harness Relocation
UAC Washer Motor Cover
UAC Aluminum Radiator Cover and Plastic Headlight Covers Covercraft Custom WeatherShield HP Car Cover
Covercraft DashMat Custom Dash Cover
Covercraft Flex Shade Windshield Screen
Audio and Electronics:
Kenwood Double Din DVD Headunit (Japanese Spec)
Kenwood Powered Subwoofer
Carozerria (Pioneer) 17cm Component Speakers (Front/Rear)
240SX Front Door Speaker Adapters
Known Defects:
Golf ball sized dent in driver's side fender and small scratch on hood
Probably could use a re-tune for US gas but idles fine
A/C was working when it arrived, but recently stopped working
Price is $20,000 cash/certified bank check. Not accepting trades at this time.
MadTyteJDM is offline
Old 07-06-2020, 10:01 PM   #2
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
soooooo far away....
badicalradical is offline
Old 07-08-2020, 08:43 AM   #3
codyzsilvia
codyzsilvia's Avatar
codyzsilvia is an unknown quantity at this point
If you ever change your mind on trades I have a nice, rust free R32 sedan with an RB25DET Neo I would swap, I miss my S13. I'm in Virginia.
METAL FOR LIFE
codyzsilvia is offline
Old 07-08-2020, 09:26 AM   #4
MadTyteJDM
Appreciate the offer codyzsilvia, but I'm trying to downsize and looking for cash only. At one point, I owned a 1991 Nissan Skyline GTR and a 1999 Nissan Skyline GT-T sedan when I was in Japan, but I no longer have those.
Old 07-09-2020, 10:18 AM   #5
astonmartian
astonmartian is an unknown quantity at this point
This is very nice - glws!
astonmartian is offline
Old 07-13-2020, 05:53 AM   #6
MadTyteJDM
Sale pending
Old 07-13-2020, 09:02 AM   #7
inferno s14
inferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-known
this car is official.
if you are interested in a 97 240 2jz ge vvti/R154 Combo/AEM standalone and gauges let me know - i will add cash on top.
worth a shot lol
inferno s14 is offline
Old 07-27-2020, 11:35 AM   #8
MadTyteJDM
SOLD! Thank you for taking a look!
