Old 11-28-2004, 10:02 PM   #1
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
SR what the hell? Maf and s-AFC problem
So when my s-AFC is hooked up my car (w/sr20det) runs just fine. Now when I unplug my s-AFC my car will not run, it acts as though my MAfs is unplugged. I can't rev past 2500rpm, idles rough etc.
Any ideas?
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 11-28-2004, 10:11 PM   #2
96twofourty
96twofourty is an unknown quantity at this point
dont you have to cut the maf wire and run it through the safc, of if ti is unplugged the ecu wont get a maf voltage?
Buy my stuff:
http://www.zilvia.net/f/announcement.php?f=10
96twofourty is offline   Reply With Quote
Old 11-28-2004, 10:12 PM   #3
allblackS14
allblackS14 is an unknown quantity at this point
Open circuit
allblackS14 is offline   Reply With Quote
Old 11-28-2004, 10:56 PM   #4
the3SecondJerk
thats what I was figuring....so i remove the harness the problem will go away?
Old 11-28-2004, 11:22 PM   #5
96twofourty
just reconnect the maf wire
Buy my stuff:
Old 11-29-2004, 07:50 PM   #6
Id-
Id-'s Avatar
Id- is an unknown quantity at this point
yeah reconnect the maf wire that was cut for the AFC install...
whats happening here is the same thing as the MAF being unplugged from the harness
95 Lexus SC300 5-speed
-DD pimp car
92 Nissan 240sx base coupe
-clean KA24DE swapped in
-GTIR T28
-Big FMIC
-565cc STi Injectors w/ Z32 MAF
-J30 VLSD w/ subframe spacers
-RPS Max clutch
-3" turboback
-PLMS Daughterboard on modded ECU
Id- is offline   Reply With Quote
