Old 11-29-2004, 05:06 AM   #1
91rusty240sx
91rusty240sx's Avatar
91rusty240sx is on a distinguished road
SR Trouble removing oil pan
okay, the SR oil pan is dented in, as usual, so i want to remove it and replace it with a better one.
i already removed the bolts that hold the oil pan to the block, but the seal on is super strong. Ive tried to jam a screwdriver between it and had no luck, what do you guys suggest? did you guys have to go through this when you removed your pan?
Tony
91rusty240sx is offline   Reply With Quote
Old 11-29-2004, 06:34 AM   #2
kandyflip445
kandyflip445's Avatar
I use a gasket scraper and a hammer. *shrug*
My 240 vBgarage
Old 11-29-2004, 12:55 PM   #3
Thrill Capsule
Thrill Capsule's Avatar
Thrill Capsule is an unknown quantity at this point
Send a message via AIM to Thrill Capsule
I took a paint scraper and slid it between the block and pan, then slid it halfway around the motor and it poped off.
Thrill Capsule is offline   Reply With Quote
Old 11-29-2004, 05:52 PM   #4
sil_8t
sil_8t's Avatar
sil_8t is an unknown quantity at this point
Send a message via AIM to sil_8t
you gotta use some elbow grease
sil_8t is offline   Reply With Quote
Old 11-29-2004, 05:49 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Or you can do it the lazy way...you can buy these gasket remover spray from kragen and itll literally melt the gasket off it. Making it alot easier to stick a scrapper between the pan and block.
