Old 08-05-2022, 09:07 AM   #1
modulation
modulation is an unknown quantity at this point
Snapped Rear Toe Rod (upper)
Everyone ever heard of someone breaking their rear upper toe arm?
Cause I did..
I haven't touched them in 12 years.
(searched around a bit and I found other reports of people who did so I feel a bit better..)
modulation is offline   Reply With Quote
Old 08-05-2022, 10:07 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
rear upper toe arm?
theres only one toe arm in the rear (one per side)
are you talking about RUCAs?
this post is incredibly vague.
did you break a stock arm? aftermarket? did you slide sideways into a curb? did it just break on its own while your car was parked? Do you live in the rust belt?
Old 08-05-2022, 10:18 AM   #3
modulation
Not the rear upper control arm.
The upper toe rod, the one that adjust toe. You can google "240sx rear toe arm" and it shows it.
It was OEM but with poly bushings. I probably should have greased the bushings more often, or done less clutch dumps or both.
Old 08-05-2022, 11:22 AM   #4
tuzzio
tuzzio's Avatar
I believe you're talking about the traction rod.
Old 08-05-2022, 12:24 PM   #5
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
I've only seen them break with poly bushings.
It's the reason I've been on a 10+ year diatribe of metal bushings or stock rubber bushings and nothing in between.
Rear suspension needs to move in a couple different axes which poly doesn't want to do.
Old 08-05-2022, 03:24 PM   #6
brndck
brndck's Avatar
right, but there is no LOWER toe rod, so when you refer to it as the UPPER toe rod, . . . . .
Old 08-05-2022, 03:30 PM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
There are only 4 rear arms on a 240sx.
Lower control arm
Rear upper control arm (camber)
Traction rod (rear caster)
Toe arm (rear toe)
