Old 07-26-2024, 03:20 AM   #1
elizabethelyea
elizabethelyea is an unknown quantity at this point
Question??
Is there any way to relocate the power steering pump to the driver side on a KA24E?
elizabethelyea is offline   Reply With Quote
Old 07-26-2024, 06:20 AM   #2
maplelaurel
maplelaurel is an unknown quantity at this point
There is always a way, it just depends on how in depth you want to go. I would imagine the alternator would need to be moved too, which means wiring etc. Maybe a remote electric powersteering setup would be a good idea.
May I ask the reason why?
maplelaurel is offline   Reply With Quote
Old 07-31-2024, 04:05 PM   #3
AKADriver
AKADriver's Avatar
No reason you'd have to move the alternator.
If you don't have A/C you could fab a bracket to put the a KA24DE PS pump down there below the distributor where the compressor would go. With it in that location the high pressure pump to rack KA24DE PS line would probably still fit.
If you wanted to mount it up higher in the KA24DE location and keep A/C you'd maybe be able to remove the cap and rotor from the distributor to gain some clearance, and use it as a cam angle sensor for a coil-near-plug setup with LS coils. but that's obviously a lot of work. At that point swapping in an electric steering column would be easier.
Old 08-01-2024, 12:22 AM   #4
chokudoriS13
chokudoriS13 is making a name for him/her selfchokudoriS13 is making a name for him/her self
Send a message via AIM to chokudoriS13
KA
Ryan!
(The message you have entered is too short. Please lengthen your message to at least 10 characters.)
S13/86/Miatas/DR30/MX83/E36 M3/S60R/E30 M3 -gone!
Now: Porsche 993/MK7 GTI
chokudoriS13 is offline   Reply With Quote
Old 08-01-2024, 08:55 PM   #5
AKADriver
AKADriver's Avatar
Vadim!!
bottom text
Old 08-06-2024, 09:57 AM   #6
chokudoriS13
Vadim!!
bottom text
We are old . And this forum is dead. Sad.
Old 08-08-2024, 07:39 PM   #7
AKADriver
AKADriver's Avatar
I dunno it's kind of fun talking to myself sometimes. Posting problems and then my own solutions. It's still better than facebook ayyyyy
