Old 09-27-2024, 09:30 AM   #1
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
1995 Nissan 240sx, Light ESP prep or blank slate for something more
Finally selling my Autocross car, I haven't used it for a while and don't see me finishing the pile of projects I had lined up for it. Here's the details.
1995 Nissan 240sx. 124k miles, 2.4l, 5 speed, base model (no sunroof mostly). The car is located in Colorado.
I bought the car in 2005 and had it as my daily driver for a few years, but since 2007 it has been a second car, in storage, etc. I was pretty regularly driving it in various stages of STX and DSP (now ESP) up to about 2015. It's quite far from "done" for street prepared and I just don't have the time to do anything with it anymore, including race it.
The car is in great shape. There's no rust anywhere and has been pretty reliable, but there is an issue with the fuel gauge, probably in the tank, and the driver's window motor or controller just went out. The paint and body are about what you would expect from a 30 year old car with 124k on it. The clearcoat on the trunk is shot and the hood looks a little cloudy. The roof has been repainted. I have more pictures or can take more if you want to see something specific.
I'm thinking $12k but can be flexible.
Powertrain
AEM intake
Hotshot Header
Magnaflow high flow cat
BRM 2.5" SS exhaust
ASP underdrive pulley
KA oil filter relocation adapter block
ACT street clutch
Fidanza 11lb flywheel
B&M short shifter
SPL Parts SS clutchline/removed clutch damper
S15 HLSD
Removed AC
Clutch fan delete (and shroud
Suspension/Brakes
Koni 8611 struts in custom housings
DC sports front STB
Ground Control spring sleeves
10k / 8k springs (550 / 450)
Jonnie Fraz front tension rod brace
poly T/C rod, anti-sway bar, steering rack bushings
Z32 brakes front and rear
SPL parts SS lines
R33 e-brake cables
Hawk HPS pads
Five lug swap
New brake MC
New front calipers and rotors
Enkei RPF1 17x9 +22
New tires 245/40/17 Sumitomo HTR A/S P03
Interior
Kognition designs carbon interior gauge panel
Autometer Sport comp II gauges (electric w/warn, oil pressure, oil temp, water temp)
Alpine headunit
Alpine front speakers
Gutted rear audio/antenna
Z32 JDM shift knob, leather w/ red stitching
Black interior (stock is ugly green)
Sparco Sprint V (D and P)
Bride sliders driver side seat rails
Planted brackets passenger side seat rails
Schroth 6 point harness
Sparco steering wheel (13" leather)
Exterior
EDM glass headlights
JDM Zenki Navan aero side skirts and rear valances
'96 grill
SE front lip
Slight pull for rear fenders, will fit 17x10, 275/40/17
Other
Python 700 alarm
Battery relocation w/odyssey battery
Odyssey battery charger
Curt receiver
Additional parts not installed
Powertrain
S13 cams
Calumsult daughter board
Suspension/Brakes
S13 HICAS steering rack
Eibach helper springs
Harder rubber bushings (rear)
SPC adjustable RUCAs, forward links
SE rear swaybar
Aluminum rear subframe bushings
Poly diff bushings
Rear control arm set (needs rebuild)
Interior
Maxworks harness bar
Exterior
Enkei RPF1 17x10 +18
Rocket Bunny replica spoiler (black)
extra stock trunklid (black)
Tire trailer
Various OEM parts
AC compressor
KA Upper intake manifolds (2)
cdlong is offline   Reply With Quote
