Old 12-10-2004, 10:13 AM   #1
BoroBoroS13
BoroBoroS13's Avatar
BoroBoroS13 is on a distinguished road
S14 Rear Sub Frame Into S13?
So yea, I have a es bushing kit that needs to be installed and I dont want to deal with having down time on my S13. I also have a S14 parts car with complete rear sub frame. Soooo, I was wondering if the S14 rear sub frame with all its suspension goodies will bolt into a S13 w/o any major work. Thanks
BoroBoroS13 is offline   Reply With Quote
Old 12-10-2004, 10:43 AM   #2
JDMark
JDMark is an unknown quantity at this point
Send a message via AIM to JDMark
nope. s15 does with minor mods, but no s14.
JDMark is offline   Reply With Quote
Old 12-10-2004, 02:49 PM   #3
BoroBoroS13
Hmmmm, that sux
Old 12-10-2004, 03:17 PM   #4
final act
final act is an unknown quantity at this point
Send a message via AIM to final act
I thought the rear s14 subframe did bolt in......are you totally sure it doesent?
final act is offline   Reply With Quote
Old 12-10-2004, 03:58 PM   #5
BoroBoroS13
Im kind of confused right now as well, I had a couple friends saying it will work but I thought it would be better to post it before I started going crazy. Where are the sub frame masters??? lol
Old 12-10-2004, 04:22 PM   #6
JDMark
at first i was pretty sure but after some research becuase im bored as hell maybe its possible
i found this post pretty helpful
http://www.zilvia.net/f/showthread.p...4+s13+subframe
Old 12-10-2004, 05:11 PM   #7
BoroBoroS13
Good find cause I know Dousan put a S15 rear sub frame into his S13 and if its true that the S14/S15 sub frames are the same then it should be the same procedure to put it in. One thing that I didnt like hearing is the poly suspension bushings wont work cause they wont flex enough to let the S14/S15 sub frame bolt in. Its looking more and more like im just gonna need to do it and see if its even possible... I hope Dousan sees this and can put shead some light on the subject though.
Old 12-11-2004, 01:05 AM   #8
jedc
jedc is an unknown quantity at this point
Send a message via AIM to jedc
Hell, give it a try and see if it works. You might just like what you find .
jedc is offline   Reply With Quote
Old 12-11-2004, 09:15 AM   #9
projectRDM
projectRDM's Avatar
S14/S15 subframe is a half inch wider than the S13, so offset bushings or the pry/bang method is required to make it fit. The Z32 subframe a full inch wider, so it requires custom drilling to the pickup points.
Either way it's not a huge benefit, the S15 subframe is slightly stiffer but a few metal rods and a welder can do that with any of them.
FORMERLY R240NA
Old 12-11-2004, 02:55 PM   #10
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Russ,
I believe my halfer-friend is swapping subframes for rust reasons.
IIRC his car was from the East Coast.. so its rusted all to hell. And he happens to have a S14 parts car laying around...
kazuo is offline   Reply With Quote
Old 12-11-2004, 06:46 PM   #11
projectRDM
projectRDM's Avatar
Originally Posted by kazuo
Russ,
Ah, no big deal, just wanted to inform him.
And that would be North East Coast if there's rust.
FORMERLY R240NA
Old 12-11-2004, 07:17 PM   #12
BoroBoroS13
Naw Art... this is for my coupe project, not my fastback (the rusted out pos). I want to do this for less downtime on the coupe cause I got to install rucas and es bushings and I want a beefier sub frame as well.
Old 12-11-2004, 09:05 PM   #13
jedc
R240NA, can you clear somethings up about your post. Do you happen to mean that the mounting points for the subframe are 1/2" or 1" wider? The subframe width per say from spindle to spindle doesn't matter as much as from bushing to bushing.
Old 12-12-2004, 02:24 PM   #14
projectRDM
projectRDM's Avatar
Correct. Mounting points are wider. The Z32 subframe from spinlde to spindle is wider also, because a Z32 diff/axle combo is too wide to fit into an S13/S14/S15.
FORMERLY R240NA
Old 12-12-2004, 03:02 PM   #15
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Swapping a subframe is a pain enough as it is. Don't do it unless you absolutely have to. Mark and I just got done with ours a few weeks ago and will never do it again.
S13Grl is offline   Reply With Quote
Old 12-12-2004, 03:25 PM   #16
sciamop
sciamop's Avatar
sciamop is making a name for him/her selfsciamop is making a name for him/her self
I certainly wouldn't do it for fun, but what difficulties did you encounter? IIRC: 6 big nuts (19mm???) + 2 small ones, disconnect driveshaft, disconnect brake lines, disconnect shocks (2 big bolts) and *BAM* it falls right out. 3 hours max...
On topic: this is a good thread. What about the J30 VLSD? Does it have the same dimensions as the Z32?
Todd
93 Coupe
sciamop is offline   Reply With Quote
Old 12-12-2004, 06:39 PM   #17
projectRDM
projectRDM's Avatar
The diff dimensions are the same for S-chassis, Z32, and J30. It's the Z32 axles that are longer, combined with 5bolt output shafts. The J30s are a direct swap, diff or axles, or both.
Swapping a subframe is really not a chore if you have a floorjack, I did mine complete with diff and arms in under 40 minutes. You just have to make sure and let it rise up flat, otherwise the front points will hit first and the subframe won't want to twist into place.
FORMERLY R240NA
