![]() Join Date: Sep 2004
![]() The key used to come out by pressing the little black botton next to the key hole. As of today it doesnt want to press in and let go of the key. I have to take the key out by lifting up the little red "latch" and then taking the key out. Im not sure why its doing that i tried wiggling the key for 30 minutes it wont come out. Maybe a fuse is buned out? Anyone have the same problem? Can someone help?
Read your FSM! Image Exceeds Forum Limits |
Is your car back in neutral or park? The sensor that tells the lock to release may be damaged or have a blown fuse. It is an accessory fuse, 15A...can't remember which one off the top of my head. I would check that, then move on to other possibilites.
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
you can also remove the lock module inside the column take off the housing remove the white box and you wont have any more issues
I never knew you could do that with an eggplant |
#6 |
i looked at the fuses none of them are burnt out. i dont know if i should take the white thing out. i dont want to mess up something.
maybe i can jam something under that red thing so it stays up forever :/ ?
Read your FSM! Image Exceeds Forum Limits Last edited by prophet_19; 12-12-2004 at 10:38 PM.. |
#7 |
I got a new battery the other day, maybe thats it. Because i looked in the manual and it says that it locks if the battery is dead. :/
#8 |
![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Hahaha. I pity you!
I had the same problem for a long time. My solution... Get skinny fingers. OR Get a needle nose pliers and just yank you the tiny lever behind the lock cylinder that you have to flip to get the thing out. Takes 5 minutes, and the button still works like normal.
#9 |
I just un plugged the module and it works fine now. Thank you for the great and correct instructions.
