Old 12-31-2004, 03:41 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Knocking noise under valve cover, searched all over..
I have a DOHC KA with 143k miles
Engine runs perfect, however
It makes a knocking noise when i start it, it gets quieter after it warms up but is still very very noticable. Its pretty obvious where the noise is coming from, its coming from inside the head.
I searched all over the internals of the head, nothing appears loose, however i do not how to adjust anything in the head. I took off the timing chain guide and no noise reduction.... so i'm stumped. If it is the valves does anyone have a link to a writeup or guide on how to adjust them and what specs to use?
Thank you!
MIKE
sepulchral is offline   Reply With Quote
Old 12-31-2004, 07:52 PM   #2
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
look on the net for a FSM file. I believe the guys at zeroyon have it. Google buddy, google.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 01-01-2005, 12:06 PM   #3
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
its either ur using too low of octane or it could be i think it was somthinglike ur sleeves are all worn out and it leaks air or pressure and it knocks
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 01-01-2005, 02:21 PM   #4
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
I have the same problem, it's most likely your timing chain tensioner. You need to replace your chain, guides and tensioners.
MELLO*SOS is offline   Reply With Quote
Old 01-01-2005, 04:39 PM   #5
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
id guess that you took off the upper most guide, thres still one behind the upper timing chain cover.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 01-01-2005, 08:23 PM   #6
sepulchral
i dont think its the chain the car had been sitting a long time like a year, when i changed the oil the old oil was as thick as mollasas. I think a lifter is sticking or something, anyone know any really good detergant oil additive?
Old 01-02-2005, 02:46 PM   #7
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
do an oil change and add a like a half of a can of seafoam to the crankcase with the oil and leave that in there for bout a 1000 miles or so. then change ur oil out again and see if you notice any difference.
l33tmonkeyman is offline   Reply With Quote
