Old 01-03-2005, 12:37 AM   #1
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
s14 Nismo 2 Way LSD Info
What are some pros and cons of the Nismo 2 way. Just wanted to see what kind of info you guys would provide.
Any information would be greatly appreciated.
Drift Indy
Edgar is offline   Reply With Quote
Old 01-03-2005, 12:41 AM   #2
OptionZero
OptionZero's Avatar
search? google?
OptionZero is offline   Reply With Quote
Old 01-03-2005, 02:12 AM   #3
Edgar
Edgar's Avatar
Sorry but I was looking at what some members tought about it. I have alot of info. Just wanted to see how the ones that own it like it.
Drift Indy
Old 01-03-2005, 08:21 AM   #4
Dousan_PG
Dousan_PG's Avatar
search its been discussed and commented many times
Aaron
Pink GodziRa
Old 01-03-2005, 11:19 PM   #5
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
its a nice set up too run for street use, but if your going too going too do a lot of TOUGE or track drifting get a Diff cooler set up. One of my customers picked 1 up from me.
racer98 is offline   Reply With Quote
Old 01-04-2005, 01:08 AM   #6
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Those are 2 situations in which you most likely WON'T need an oil cooler for your diff. I would suggest it for a vehicle used in endurance races but not drift or mountain driving. I've had my diff for about a year now and done about 8 or 9 drift/track events, a shitload of canyon driving as well as canyon drifting and have never burned my oil. I have changed my diff oil before every event and it's always golden yellow with a hint of green from the diff additive I always put in. Oil cooler for a diff in a drift car is SUPER OVERKILL in my opinion. Like dousan said, clutch packed diffs eventually go out over time. Change your oil after every event and it will last a long time. My tomei 2 way has been engaging the same from the first day I installed it.
Flybert is offline   Reply With Quote
Old 01-04-2005, 12:10 AM   #7
Dousan_PG
Dousan_PG's Avatar
bullshit
ive been running touge and track and NEVER had ANY use for a diff cooler
and neither do i see most people stateside OR japan
Aaron
Pink GodziRa
Old 01-04-2005, 12:29 AM   #8
racer98
racer98's Avatar
Originally Posted by Dousan_PG
bullshit
Oh boy here we go again !
its dependent on each persons thoughts or blind hatetred.
but if you want your diff too last longer its better too run a diff cooler sure you can run with out one but each case is differnt. much rather run one then not if your planning on keeping for a long time run a diff cooler but if not who cares.
Old 01-04-2005, 12:36 AM   #9
Dousan_PG
Dousan_PG's Avatar
mm considering friends overseas w/ 2+ years on the same diff
if you change your oils often, run a good weight then you wont face problems
mine has had no problms, neither have friends
overtime a rebuild is always in order, cooler or not
Aaron
Pink GodziRa
Old 01-04-2005, 10:29 AM   #10
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
^ fly bert what diff oil do you use and what additive?
MasterOFDrift is offline   Reply With Quote
Old 02-07-2005, 12:11 AM   #11
akihabro
akihabro is making a name for him/her selfakihabro is making a name for him/her self
he uses ford friction modifier as for oil i forget
akihabro is offline   Reply With Quote
Old 02-07-2005, 05:35 AM   #12
vegita319
vegita319's Avatar
vegita319 is an unknown quantity at this point
Send a message via AIM to vegita319
Pros:
very quiet, and locks pretty good for the most part. Can use synthetic oil like redline with additive already built in to it, so theres no need for additional additive.
Cons:
shitty tires mean chirping alot when making turns (I'm pretty sure this applies to all lsds). Just get better tires adn problem solved. Causes extreme addiction to driving and won't let you get other things done. Makes you want to throttle the gas hard coming around every corner. Other than that, none really.
Enjoy the nismo, or any lsd for that matter. It has 12 clutch plates (or 16 in dousan's case) which is alot better than open diff and vlsd. You cant go wrong.
vegita319 is offline   Reply With Quote
Old 02-07-2005, 05:53 AM   #13
sideviewcivic
sideviewcivic has a little shameless behavior in the past
Send a message via AIM to sideviewcivic
Originally Posted by vegita319
Pros:
Cons:
and when the car is cold aka all fluids are cold, nismo lsd will be louder initially, but will get quiet once the fluid has warmed up 80w90/140 should be used. MrMigs spoke to a nismo technician, and they stated to use non-synthetic over synthetic for longevity, whether that is opinionated or factual, it does hold some weight considering a nismo technician. *Tears* during break-in, so much popping and clunking, i was so happy, then i changed the fluid and it got quiet. correct me if im wrong but i heard if you run 80w140 the clutch plates will engage harder.
Dousan do you know if they have released rebuild kits yet. I want to sandwich in more plates eventually by end of summer
-Aaron
sideviewcivic is offline   Reply With Quote
Old 01-04-2005, 04:27 PM   #14
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
what about just welding some heat soak fins onto the stock diff cover?
and I would think that a diff that was "burning" oil has very serious problems.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
