Hey there, as you probably know I made a deal for a 95 240sx se for $6300, I'll be getting it when I sell my 89 celica.
anyways, when I took the 240 onto the freeway, the steering wheel vibrates back and forth, when i got faster than 65 the vibrations get closer together, and the steering wheel doesn't align straight. My question is... does the car just need a wheel alignment?
Current Cars: 1976 Mercedes Benz 300D 1995 240sx SE aka Kate (winner: Best Stock S14 @ 2002 National Convention) http://community.webshots.com/user/jeff976cal If you're interested in parts email me [email protected] |
Most likely a bent rim or your wheels/tires need a high speed balance. This is a notorious problem with s13. The wheel vibrates at 65mph, disappearing as speeds decrease or increase.
I got rid of my "most" of my wobble by replacing tie rod ends, tension rods, and alignment. These are other areas which may cause this wobble. But I would check your wheels firsts, see if they are bent. If so, swap and test drive again. Good luck.
Beware the fury of a silent man, be more cautious of his silent farts.... |
![]() Join Date: Aug 2001
mine does the same damn thing at 65.. once i'm going 75 it's smooth.. and anythign under 63ish it's smooth... i have an s14 tho..
__________ 96 s14 300zx lsd zeal b2's |
you probably threw one of the lead weights...you might need to get your wheels balanced...i was experiencing the same problem last weekend...got my wheels balanced and it's all better...
it's called a life...maybe you should get one!!! |
#5 |
![]() Join Date: Feb 2002
Just get a Ballance and alignment that should fix your problem it did mine. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt='
http://www.cardomain.com/memberpage/509537 http://www.imagestation.com/album/?id=4287415487 http://www.zilvia.net/f/showthread.php?t=21036 |
#7 |
Mine did it for a month, But I took it in and poof it was gone now i'm good from 0-119 <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt='
