Old 01-19-2005, 07:26 PM   #1
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
Unhappy will not start
Ok so my car runs great! the only problem is that it will not start by the key. So If I roll it down a hill and jump it off it runs and pulls hard. But If I turn the key the car trys to crank (meaning the starter moves the pistons) but the car never fires. If anyone has any idea what this is I would greatly appreciate it
Thanks, Brandon
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 01-19-2005, 07:38 PM   #2
s14unimog
s14unimog's Avatar
Trader Rating: (22)
I have an aftermarket alarm and I'm thinking thatmight have something to do with it. does anyone else have an idea?
Old 01-19-2005, 08:20 PM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
help anyone
Old 01-19-2005, 08:35 PM   #4
97DubTruck
97DubTruck is making a name for him/her self97DubTruck is making a name for him/her self
Try the grounds.
97DubTruck is offline   Reply With Quote
Old 01-21-2005, 09:02 AM   #5
s14unimog
s14unimog's Avatar
Trader Rating: (22)
the car turns over fine so I'm guessing that its not a ground. The thing just wont catch to fire. something is happening when the key is turned, maybe the coils are losing power. I'm stumped!
heard about the coupe jay. daily driver?
Old 01-22-2005, 02:36 AM   #6
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Thanks, Brandon
Brandon,
Remove the steering column cover and examine the ignition switch module.
http://replacement.autopartswarehous...gnition+Switch
It's possible that you could have a short in the ignition switch module. Only way to know for sure is to remove the two small phillips head screws holding the ignition switch module in place, (directly opposite of where you insert your key into the ignition/steering wheel lock). Remove the ignition switch module from the steering column & unplug it from the wiring harness. Once you do that, then take a ohm/volt meter or continuity tester & test the switch in EACH position....OFF / ACC / ON / START. Make sure all the position of the switch are working properly & there are NO electrical shorts in any of the positions. If there is, then replace the switch. A faulty ignition switch module can cause the problems you are having now. You can order a replacement at the above mentioned link.
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 01-22-2005, 05:31 PM   #7
s14unimog
s14unimog's Avatar
Trader Rating: (22)
thanks
I did just that about. Thanks and your right that is the problem. I took that apart to discover burned terminals. Thanks for the link
Thanks, Brandon
