Old 01-22-2005, 12:00 PM   #1
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
Anyone Who ever had SR rod knock
It was brought to my attention last night that Sr's MAY have a problem with the #2 cylinder having rod knock.
A friend was telling me about how his friend threw a rod on his sr, on the #2 cylinder. They got a replacement n/a SR block from an AUTOMATIC sentra. When they pulled the head off they found that it also had a bad rod bearing in the #2 cylinder. Last Saturday at the racetrack my friend Luke(Blu808) threw a rod on his SR, and i believe it was also #2. Does anyone have any info about this problem or is it just a coincidence?
Did your SR throw a rod? What number cylinder was it?
I didnt do a search. forgive my laziness.
Hi
Var is offline   Reply With Quote
Old 01-22-2005, 01:24 PM   #2
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
This is a widely known issue with FWD SR20 engines. It seems that most of them spin the #3 bearing but #2 happens also. It's not a "daily driver" problem, usually happens as a result of high RPM plus oil starvation. The result is that most of us run synthetic oil and check it OFTEN.
If you want more info head over to www.sr20forum.com and search for "spun bearing" or "rod knock" and you'll get a ton of hits.
Hope that helps.
FYI - you can get a low-mile JDM engine for under $500 (sometimes under $400) from Soko and a few other suppliers. They're usually quite reliable and most of them come from automatic tranny cars, so they're usually not beat-up.
Rittmeister is offline   Reply With Quote
Old 01-22-2005, 01:36 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
#3 on mine...then again my oil pump went out so that might be a different story. OUCH...luke blew another engine. Sorry to hear that
Old 03-21-2006, 07:32 AM   #4
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
i know this is a old topic but i couldnt find any others so dont go bull shitting about it
my sr20det just spun a rod bearing i belive or i fucked it up i got my valve cover painted and put it back on drove it home and noticed oil coming out the back well the left came seal (looking at the motor) in the back didnt seal it was actuallly leaving a big hole could that have caused it. well oil was everywhere so i fixed that then pressure washed it not directly on filters or elctrical stuff.
rotation3x is offline   Reply With Quote
