Old 01-28-2005, 10:47 AM   #1
duey
duey's Avatar
duey is an unknown quantity at this point
S13 Redtop -> S14 = will not start
harness was done by enjuku. The car cranks, spark and actually will start if starting fluid is used. Fuel pump does NOT come on BUT we have hardwired the fuel pump to get fuel and have pressure, sparkplugs/coilpacks have been replaced/checked with known good ones.
Few problems i've thought up of is :
1. bad ecu (waiting for a replacement)
2. bad injectors
3. injector/fuel pump wiring
Anyone have any other ideas/suggestions?
http://members.cardomain.com/duey170
12.3@111mph - basic mods/STOCK t25
duey is offline   Reply With Quote
Old 01-28-2005, 01:56 PM   #2
TheTicTac
TheTicTac's Avatar
TheTicTac is a well-known jackass
Fuel lines on backwards?
*GorgeousGarage* L.oose S.ocks D.aisuke !
TheTicTac is offline   Reply With Quote
Old 01-28-2005, 03:47 PM   #3
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
if you got the pump working than check your fuel lines lit tictac said remember the return line comes off of the regulator
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 01-28-2005, 07:16 PM   #4
duey
duey's Avatar
got it running finally, wasn't the fuel lines those were on correct. The wiring near the ecu was incorrect, i had to re-wire it and she started right up.
Now my next question, when enjuku did the harness there wasnt a wire located in the "ECU FAULT CODE" spot (can't remember which pin off the top of my head), i'm not sure why the wire would not be there, could it be because the check engine light will not work correctly with an s13 redtop in an s14?
