Old 02-02-2005, 11:36 PM   #1
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
sohc-dohc i searched but cant find this question
ok i now know i gotta switch gauge clusters, but what about the harness under dash goin to it? when i went and got the harness all i got was the part that goes from the ecu to the motor. is that all i need or do i gotta get the one thas under the dash too? cause if the sohc harness hooks right up to the dohc cluster i should be alright. right? i hope so cause i think they crushed the dohc car. thanx hope someone can help
sil80forme is offline   Reply With Quote
Old 02-03-2005, 03:03 AM   #2
s13irdie2
s13irdie2 is on a distinguished road
the dohc cluster plugs into the sohc body harness. make sure you use the tach from the sohc cluster cause the tach wont work on the dohc one.
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 02-03-2005, 05:56 AM   #3
sil80forme
sil80forme's Avatar
so i gotta use the dohc cluster with the sohc tach? am i correct?
Old 02-03-2005, 08:04 AM   #4
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
you just need the dohc tach, the rest of the cluster is the same.
black s13 is offline   Reply With Quote
Old 02-03-2005, 08:29 AM   #5
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
First reply was wrong
You can do one of two things.
1. put dohc Tach into your gauge cluseter (SOHC)
2. replace gauge cluster with the one from the DOHC model, and yes it plugs right in.
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 02-03-2005, 10:01 AM   #6
s13irdie2
i used the dohc gauge cluster on the sohc body harness and it worked so my reply wasnt wrong.
1990 s13
Old 02-03-2005, 10:47 AM   #7
projectRDM
projectRDM's Avatar
From your post:
"make sure you use the tach from the sohc cluster cause the tach wont work on the dohc one."
So you say to use the SOHC tach, yet you used the DOHC tach in yours? Yes, I'd say your reply was wrong.
FORMERLY R240NA
Old 02-04-2005, 10:04 PM   #8
s13irdie2
Originally Posted by R240NA
From your post:
i never said i used the dohc tach in mine. i said i used the dohc gauge cluster with the sohc tach.
1990 s13
Old 02-03-2005, 03:07 PM   #9
Phlip
Yes, I look like that
Phlip's Avatar
I used the whole twincam cluster, because I was changing from HUD to analog at the same time.
... and before ANY of you motherfuckers asks why, it was because I bought the car as a shell sans engine and the windshield was cracked, the cluster was an even exchange, I will sell the HUD shit and the windshield will be cheaper
Weirdo
And I write too!
Old 02-03-2005, 08:26 PM   #10
the head
the head's Avatar
I feel ya on the HUD thing the digital part of my dash was fried when i got the car so I changed to the analog cluster as well
btw your title is fuckin great
Old 02-03-2005, 08:32 PM   #11
Phlip
Phlip's Avatar
My problem was not with the OPERATION of the HUD, my problem was with the fact that I was switching frome SOHC to Twincam, AND swapping auto to 5-speed AND the windshield happened to be cracked... The cluster available to me for my 5-speed/twincam swap was FREE and the windshield for analog would be a LOT less expensive, I jumped on it, ya know?
Weirdo
And I write too!
Old 02-04-2005, 07:43 AM   #12
the head
the head's Avatar
I see your thing I did auto to manual and sohc to SR so i needed the tach also hence the reason i did not try to fix the hud system
Old 02-04-2005, 03:14 PM   #13
sil80forme
sil80forme's Avatar
why?
HEAD why is my title so fukin great?
