Old 02-18-2005, 04:30 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
ahh, I need tranny help
This is like the third 240 tranny that I have done, not on my car, and it is deffinitly the most difficult. I cant get it to come all the way off, the edge of the bell housing is out about 3/4 of an inch and thats were it is staying, I have twisted, pried, hanked and anything else you can think of for quite some time. any sudjestions. thanks.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 02-18-2005, 04:37 PM   #2
sdtouge
sdtouge can only hope to improve
um, inda obvious things but you never know,
did you get all the bolts? there are like 3 that are really hard to reach
unbolt drive shaft?
unbolt starter?
unbolt slave cylinder?
unbult tranny crosmeber from tranny and exhaust?
take off all sensors from tranny
is it stuck on something? you kinda have to twist it a little bit, i forget wich way but i think its toward the passenger side.
good luck.
matt
sdtouge is offline   Reply With Quote
Old 02-18-2005, 06:17 PM   #3
Mr. Spool
Thanks matt, yeah its all off, it almost feels like its catching on something inside the bellhousing or near the clutch. I am about to loose my mind trying ot figure this one out. any more help would be apreciated. thanks.
96' SE Turbo'd
Old 02-18-2005, 07:11 PM   #4
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
heat cover on speed sensor at 12 o'clock on tranny belhousing will catch on teh body if you forgot to unbolt it(10mil bolt) i had this problem first time i did the clutch on my car ended up destroying the damn sensor and bent the hell out of the heat shield
Al_S14 is offline   Reply With Quote
Old 02-18-2005, 08:26 PM   #5
Mr. Spool
not quite sure which one you are talking about, the engine and tranny are pointing towards the ground, kinda, you mean the crank angle sensor, the one on the very top of the tranny, it shouldnt be catching, I have rotated the tranny several times trying it in different possitions, any body had the tranny just not want to come off. thanks.
96' SE Turbo'd
Old 02-18-2005, 10:50 PM   #6
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
yeah that sensor will get you every time, hmmmmmmmmmm
Parting out SR build....
Campos is offline   Reply With Quote
Old 02-19-2005, 12:33 AM   #7
max_misawa
max_misawa is an unknown quantity at this point
put a 2X4 under the crank pulley and jack up on the piece of wood a little?
Max
max_misawa is offline   Reply With Quote
Old 02-19-2005, 08:19 AM   #8
Mr. Spool
I dont think that it is hitting on anything on the out side, the engine is already tipped pretty well to the back. it is however getting caught on the inside, is it possible that the pilot bushing is fused on the end of the tranny shaft, preventing the tranny from making it past the splines on the flywheel? any more thoughts?
96' SE Turbo'd
