Old 02-19-2005, 05:25 PM   #1
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
sohc-dohc harness Q
ok i have read up on this numerous times and even read the swap in the tech section, but for some reason the tech sec doesnt work now, anyway i have the harness from the motor to the ecu, and the dohc ecu thas it, now when i read the install it didnt say anything bout the interior harness, so i didnt get one, well i go to install the harness and ecu today and the set of wires that comes off the blue cluster that plus into ecu ( brown clip) doesnt fit into the white clip that is attached to the rail goin accrosss the front of the car, should i just get the whole interior harness or cut and splice, i was just goin to do this but the wires are all different soo can some one please help me out thanx
sil80forme is offline   Reply With Quote
Old 02-19-2005, 06:25 PM   #2
ruthlesstyper
ruthlesstyper is an unknown quantity at this point
you don't need the interior harness, but u need DOHC tach.
ruthlesstyper is offline   Reply With Quote
Old 02-19-2005, 07:00 PM   #3
sil80forme
sil80forme's Avatar
then what do i do bout the harness not workin they dont clip together like they are suposed to
Old 02-19-2005, 07:53 PM   #4
ruthlesstyper
I believe you are reffering to the plug that is for the gauge cluster. They should be the same dude.
Old 02-19-2005, 09:44 PM   #5
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
no, they should not be the same.
its the only wiring needed for the swap, as is always mentioned when this subject comes up.
just vut both harnesses in half (the small ones, both SOHC and DOHC) take the sohc chassis half and the dohc ecu half and match up the wires(color to color.) only like 7 match, thats all you need.
and youre done.
black s13 is offline   Reply With Quote
Old 02-20-2005, 01:20 AM   #6
sil80forme
sil80forme's Avatar
nice thank u thas what i wanted to know, i counted 15 wires on one and 16 on the other and only a few matched colors, thanx
Old 02-20-2005, 04:07 PM   #7
black s13
black s13's Avatar
any time.
message legnth.
Old 03-06-2005, 06:02 PM   #8
Sularus
Sularus is an unknown quantity at this point
does anyone have any pics of this. I will be doing this soon and I personally would like some pics unless it is that obvious and I can't miss it.
Sularus is offline   Reply With Quote
Old 03-06-2005, 06:15 PM   #9
Phlip
Yes, I look like that
Phlip's Avatar
according to black s13 and personal experience with working with the guy doing my own, it IS obvious, unless you encounter some other arbitrary problems, as we have
Weirdo
And I write too!
