Old 02-22-2005, 02:09 PM   #1
c0axiL
c0axiL is an unknown quantity at this point
Send a message via AIM to c0axiL
s13 how do i make an auto ecu in a manual car
what needs to be done for a auto ecu to work in a manual car. its has the sohc to dohc swap?
c0axiL is offline   Reply With Quote
Old 02-22-2005, 02:16 PM   #2
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
is the ECU you are trying to put in SOHC or DOHC? second why wouldn't you just find a manual ECU?
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 02-22-2005, 02:20 PM   #3
c0axiL
the car is originally an sohc, then a dohc motor was put in and the ecu is dohc. im not sure why not get another one im doing this for a friend.
Old 02-22-2005, 03:54 PM   #4
the head
the head's Avatar
when you hook it up what doesn't work?
Old 02-22-2005, 05:05 PM   #5
thx247
thx247 is an unknown quantity at this point
If the ecu is the same vintage as your car it should work fine. No speed limit to worry about and a higher redline too. OBD I ecu's will only with with OBD I motors, and the same applies to OBD II motors and Ecu's.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
Old 02-22-2005, 08:51 PM   #6
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
ok i asked a friend to post this topic for me while i was at school. (thanx coaxil) anyway when i had my 91 hatch i did the auto to manual swap and kept the auto ecu, when i was finished it wouldnt start, so i had to take the bottom harness under the relay terminal, and splice together, well i got rid of that and bought a 89 coupe 5spd and saveed auto ecu and dohc outta the 91, for the sohc to dohc swap, now my question is wil the dohc auto ecu work fine, i dont have that original harness that i spiced, and the 89 5spd is different so i was wondering if there will be any reason why it wont start 2 morrow, (anything to do with the fact that its an auto ecu) so i hope this helps explain everythin thanx
sil80forme is offline   Reply With Quote
Old 02-22-2005, 09:48 PM   #7
projectRDM
projectRDM's Avatar
ECU works with the motor. 89-90 all work together, 91-94 all work together, and 95-98 work together. Auto, manual, either ECU will run it. If you've swapped a 91-94 motor in, then you need a 91-94 ECU. Simple.
FORMERLY R240NA
Old 02-23-2005, 03:06 AM   #8
sil80forme
sil80forme's Avatar
ok thanx thas all i needed to know
