Old 03-25-2002, 06:17 PM   #1
fidelis240
fidelis240 is an unknown quantity at this point
I'm sure someone's asked this before, but the search feature isn't working on my computer at the moment.
I have a '95 SE 5-spd w/ an Injen underhood intake.  When I  give it gas to leave from a stop, there is about a second (or more) lag before the engine revs.  If I just blip it for heel-toe downshifting, sometimes it doesn't rev up at all.  It's very annoying and is leading to me killing the engine often.  I was told it might be that those sh***y plastic guides (timing chain or cam?) broke and are causing a timing problem (the exhaust does smell a bit rich).  Any help?  Thanks in advance.
fidelis240 is offline   Reply With Quote
Old 03-25-2002, 08:21 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Check your hoses and clean the throttle. You may just have some carbon deposit that's causing the air not to be delivered properly.
S13Grl is offline   Reply With Quote
Old 03-25-2002, 09:27 PM   #3
Arcane
Arcane is an unknown quantity at this point
i had the same problem a month and a half ago...it's probably your throttle body...i cleaned mine up (it was nasty!!! ) and everything was running honky dory...
it's called a life...maybe you should get one!!!
Arcane is offline   Reply With Quote
Old 03-25-2002, 09:32 PM   #4
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
check your throttle cable thats more than likely the cause.
the throttle body not being clean would not be the cause but is a good idea to clean it out
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 03-25-2002, 10:37 PM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
also check leaks in the intake where it goes together.  If the maf is judging the amount of air going in incorrectly then it can cause the engine to bog down.
sykikchimp is offline   Reply With Quote
Old 03-25-2002, 11:57 PM   #6
adey
adey's Avatar
adey is an unknown quantity at this point
I know how you feel, that's what driving a car with drive-by-wire is like. When I downshift I have to "blip" the throttle by punching it to the bottom (WOT) for a split second for the rev to come up just 1k rpm. it's ridiculous.  oh, that's on a MkIV Volkswagen, fwiw.
All I can think of would be a dirty/clogged air filter or related parts. having the open element should actually increase throttle response.
Best of luck!
Instagram: @SX180HKG
adey is offline   Reply With Quote
