Old 03-20-2005, 08:52 PM   #1
Farbs
Farbs is an unknown quantity at this point
Send a message via AIM to Farbs Send a message via Yahoo to Farbs
Help me with my j30 LSD problem!!!
here is the current post, sorry i'm too lazy to retype it all
http://www.clubfr.net/forums/index....t=0&#entry24841
Thats my post on a diff board, too much work to redo everything on here, see if that works
Farbs is offline   Reply With Quote
Old 03-20-2005, 09:41 PM   #2
projectRDM
projectRDM's Avatar
"Page not found".
FORMERLY R240NA
Old 03-20-2005, 10:17 PM   #3
slivia-junkie
Location: if you could tell me i would be most greatfull
slivia-junkie is an unknown quantity at this point
cannot display page, no info no help, also saying your to lazy to re-type doesn't make you sound good a simple cut and paste is so much better
slivia-junkie is offline   Reply With Quote
Old 03-21-2005, 12:23 AM   #4
Farbs
ahrrggg okay, nvm, let me cut and paste
Old 03-21-2005, 12:33 AM   #5
Farbs
Hey guys,
Well today I started this project with a few buddies and we basically have the old open diff off, just have to take off the 2 19mm bolts in the back towards the rear end (already losened)
My question is I seems like one of the side bushings are missing on the j30 lsd... I'll try and put up a pic if I can figure it out. The thing is I would have noticed it earlier but i bought the thing in the beginning of the summer and never had time to get around to it because I was going off to my first year of college. Anyhoo if anyone can give any pointer or what to do about this bushing or any suggestions overall, that would be wonderful
Thanks,
Scott
Old 03-21-2005, 03:01 AM   #6
SimpleSexy180
dealer or junkyard...
SimpleSexy180 is offline   Reply With Quote
Old 03-21-2005, 03:06 AM   #7
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
hmm yah im missing a bushing too come to think of it, so ill go to the dealer for a 93 j30 bushing? also can I put it in myself, or do I need a press,
mjjstang is offline   Reply With Quote
Old 03-21-2005, 09:31 AM   #8
projectRDM
projectRDM's Avatar
Use your existing S14 bushings, they're the same.
FORMERLY R240NA
Old 03-21-2005, 11:57 AM   #9
Farbs
what Mjjstang said, can I put it in myself or do I need a press?
Old 03-21-2005, 11:59 AM   #10
Farbs
Okay now someone is tell me I have to swap the LSD covers. From what I read/found out I thought if you are installing on a s14, the j30 lsd you don't need to swap the covers...If I do need to swap the covers whats the signs that I do? Like it won't fit when I try to put it in?
Old 03-21-2005, 12:48 PM   #11
SimpleSexy180
the back cover you have right now has 2 studs right? becuase on s13's it requires 4 studs.
Old 03-21-2005, 01:17 PM   #12
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
do you have s14? or s13? the way it is now its fine for s14.... if you have a s13 you need to swap that back cover....
SR240DET is offline   Reply With Quote
Old 03-21-2005, 01:25 PM   #13
mjjstang
wait a minute, that looks like a 6 bolt, Ithoug hthe j30 were 5 or is it just 93, also I musta been tired when I looked, and thought i had a bushing, neither my stock r200 or my vlsd have bushings,
Old 03-21-2005, 07:43 PM   #14
Farbs
I have an s14, I don't need to do any modification. I just want to know how to get the stock bushing off and onto the j30 lsd. That is the only issue. The 95-96 j30 lsd's have the 6 bolts on the output shafts
Old 03-21-2005, 08:16 PM   #15
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
Look up a post I made. I had the same issues when I got the J30 VLSD.
It was missing a bushing also. Since I had an S13, my open diff didn't have any bushings. I ended up buying an ES Kit online for about $30. Included 2 of those bushings and another 2 for the subframe.
I have part #'s in my other post. I think I tried calling Infiniti/Nissan for the bushing but they wanted $30 alone... so it was much more cost efficient to buy a bushing kit.
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 03-21-2005, 08:45 PM   #16
Farbs
How hard was it to pop them out/put them in?
Old 03-21-2005, 10:02 PM   #17
projectRDM
projectRDM's Avatar
They fall out when you drop the diff. There's actually an upper washer above the bushing, and a washer below. Just use all the parts off your old diff to replace what's missing, it's all the same.
FORMERLY R240NA
Old 03-22-2005, 12:29 AM   #18
Farbs
alright so it should come out go back in easy then?
Old 03-22-2005, 02:41 AM   #19
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
You can do it yourself. Take a can of PB Blaster, flip the differential upside down with the bushing facing downwards & spray the old J30 bushing. Let it sit for a few minutes, then take a hammer along with old rachet socket & bang away at it. After a few good wacks the old bushing should pop right out. Putting in the new ones are a lot easier than the old ones...they just slide right on in.
I did this when I installed my J30 VLSD on my S14. I used the Energy Suspension 300ZX rear differential bushings, (I think the part # is 7-1108??), as replacements for the old J30 bushings.The Energy Suspension bushings work just fine.
You shouldn't have any problems installing the VLSD, everything bolts right up. Just be careful that your driveshaft doesn't rub up against the exhaust resonator. Mine does...those Nismo exhaust hanger bushings sure pull your exhaust tight against the car frame. My N1 dual resonator scraped a line on the drive shaft on mine. Gonna have to crawl underneath the car again & see how the driveshaft is making out.
ID
'95 SE with J30 VLSD
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
