Old 03-24-2005, 05:27 PM   #1
NemeGuero
No more nissan.
NemeGuero's Avatar
KA no clutch pedal pressure(AT-MT swap)
so, I'm 95% finished with the manual tranny swap and I filled up the MC with brake fluid. check. double checked the hardline. check. called my buddy over to help me bleed the pedal. he pushes it in and it just hits the floor and stays.. ('cuz of the spring on the pedal). so I ask him to pump it by hand and pull it back up. still nothing, the fluid level doesn't drop. so I checked the pin on the pushrod for the MC and it's fine. opened up the bleeder on the slave and a little air pushes out but no fluid and no fluid level change either. could my hardline be clogged?
thanks
Evan
Old 03-24-2005, 05:42 PM   #2
TheTicTac
TheTicTac's Avatar
TheTicTac is a well-known jackass
Did you bench bleed the MC, sometimes there could be air in it. Did you remove the dampening system? That could sometimes be a pain to bleed.
*GorgeousGarage* L.oose S.ocks D.aisuke !
TheTicTac is offline   Reply With Quote
Old 03-24-2005, 05:45 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
what is bench bleeding? guess that's an obvious no... and yes I removed the dampening system.. ran the hard line right to the rubber from the slave
Old 03-24-2005, 06:31 PM   #4
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
just keep bleeding it, eventually it will work for ya
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 03-24-2005, 06:36 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
even if no fluid drips out?
Old 03-26-2005, 12:38 AM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
Popular consensus: bench bleed and then just keep bleeing the line after that?
Old 03-26-2005, 02:37 AM   #7
fastbacchris
fastbacchris's Avatar
fastbacchris is an unknown quantity at this point
same thing happen to me just keep blending.
90 auto shell 92 motor 96 trans
fastbacchris is offline   Reply With Quote
Old 03-26-2005, 10:25 AM   #8
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
you just need to keep on bleeding there is a lot of air in your system, cause it was dry.
New Video
Buy my mounts!
Old 03-26-2005, 11:09 AM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
thanks people.. driveshaft arrives wednesday! i'm so excited... 2 years of auto... I want to pull an office space and take the auto tranny out to an empty field and blow it up
