![]() Join Date: Aug 2004
High Idle right after 5 speed swap
Ok I did a search and came on this thread about the guy car's running rich. He was idling high and tried replacing iacv, rotors, caps, plugs, wires, fuel filter and so on. I did the same stuff and i even adjusted the idle and the lowest it would go is 1000. I was trying a bunch of things and all of a sudden, when i unplug my EFI harness, the idles drops normal and i can adjust the screw to get 700 rpms.
The only problem is when i plug the efi harness back, it shoots back up to 1500. I dunno if its my IACV or not but adjust the screw does make a difference. That leads me to think its fine. It's been idling high after the 5 speed swap and I have searched and no one else that has done the swap had high idle for the ka. I checked all the hoses for vacuum leaks, and I've checked the timing as well. I'm pretty much out of ideas. Ctune has looked at it as well and they are stumped! So any other suggestions would be helpful. Edit- O yeah, I already pulled codes and it shows 55, meaning everything runs fine. |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
sounds like your IACV is stuck open claen that bich out with some carb cleaner probably just carboned up and stuck
I never knew you could do that with an eggplant |
Yes, I look like that
![]() Join Date: Mar 2002
Are you still using the auto ECU? If so that is your problem, get used to it or get a manual ECU
http://www.zilvia.net/f/showthread.php?t=74615 |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
normal auto ecu stuff, but if you go to the 5 speed ecu you will lose a few cool things.
The auto ecu on a S13 is actually a secret weapon performance upgrade. Ya you get the funny drop to idle issue but the trade off is no speed cut!! Higher rev limit 7200 and a better curve . Yes a better curve!! Why because auto trannys are much different than clutch manual setups . So the ecu maps have a different curve to them. All the auto cars I have swapped have always been quicker useing the auto ecu. vs a 5 speed ecu car.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
#6 | |
