whats a good power source?
whats a good power source to connect the gauges too.... i connect it to the cig lighter for temp.. and all its doing is blowing out fuse by fuse........ so need a new source now. where do you guys connect the gauge too?
´¨) ¸.·´¸.·´¨) ¸.·´¨) (¸.·´ (¸.·´ .·´¨¨°º3 stArRº°¨¨°º ![]() ![]() |
![]() Join Date: Oct 2003
the gauge, ah yes, i have the gauge installed as well, its JDM tyte...please be more specific, are you looking to power a gauge, are you looking to power a light on a gauge so it lights up at night when you turn on the headlights?, also might i suggest investing in a multimeter
12v+ Accessory provides 12v+ only when your car is in ACC Mode on the KEY.
This should help 12 VOLTS white + ignition harness STARTER 1 black/white + ignition harness STARTER 2 black/yellow + ignition harness IGNITION 1 black/red + ignition harness ACCESSORY 1 blue + ignition harness POWER LOCK orange/black F driver's kick panel To operate, open (cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock. POWER UNLOCK same wire F To operate, open (cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock. PARKLIGHTS POSITIVE red/blue + back of dash dimmer PARKLIGHTS NEGATIVE - HEADLIGHT grn/yel, grn/blue + steering column BRAKE red/green + brake pedal switch DOOR PIN red/white - courtesy light TRUNK PIN red - sw. or light in trunk TACH yellow/red ecm pass. kick panel LEFT FRONT UP/DWN green, blue driver's door switch RIGHT FRONT UP/DWN red/white, red/black dr. door or kick panel HORN green/white - steering column WIPER lt. green/red - steering column RADIO 12V red/black + radio RADIO SWITCH blue + radio RADIO ILLUMINATION red/blue + radio POWER ANTENNA black/red + radio LEFT FRONT SPEAKER brn/wht - brown radio RIGHT FRONT SPEAKER blu/wht - blu/yel radio LEFT REAR SPEAKER purple - pink radio RIGHT REAR SPEAKER red - green radio
#6 | |
![]() Join Date: Apr 2003
on the same note, what's a good source to tap for electric fan if i want it constantly on with ignition?
![]() Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
#7 | |
![]() Join Date: Jun 2003
![]() Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
#8 |
![]() Join Date: Dec 2002
Safely, there is none. The main ignition to the key switch is the only high current ignition wire in the car, but tapping off of it without a relay may overload the circuit. Then you'll be buying those pretty 45A fusible links every few days. Use a relay, do it right.
#9 |
![]() Join Date: Jan 2004
i used a $25 painless wiring relay kit from summit racing for my Efan and and i hooked it up to the fuel pump fuse. it works perfectly and doesnt' allow current to flow back into the circuit when i shut the car off. without a relay you'll turn the car off, the fan will still spin, and it could feed back enough current to keep the car alive for a few seconds then sputter, backfire, and die.
not so good for impressing the ladies. relays are king. |
