Old 05-19-2005, 12:29 PM   #1
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
SR Dip stick popping out...
So i rarely show my motor off and do anything crazy, but I did it yesterday on the onramp to the 101... I was shifting at around 6000 rpm and by the time I hit 4th, smoke in the rearview mirror... heart sinks but that car still drives normally. So the dipstick popped out about an inch and shot oil on the manifold. What caused this? How can this be prevented? It has happened once before. Also, the car feels a little sluggish at low throttle below 3500 rpm and it has been runinng a little warm but not overheating.
Thanks,
Ryan
Pudula is offline   Reply With Quote
Old 05-19-2005, 12:32 PM   #2
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
caused by positive pressure in the crankcase see if the PCV hoses are clogged
take the PCV valve out and shake it if it doesnt rattle or sticks you may want to replace it
I never knew you could do that with an eggplant
Last edited by the head; 05-20-2005 at 07:49 AM.. Reason: wrong abbrivation EGR to PCV
the head is offline   Reply With Quote
Old 05-19-2005, 05:08 PM   #3
broken_s13
broken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enough
it happens to me too. i just wrap the dipstick with tefflon tape. How would u check your egr valve.
broken_s13 is offline   Reply With Quote
Old 05-19-2005, 05:11 PM   #4
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
check your pcv, egr is exhaust gas, pcv does crank case pressure
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 05-20-2005, 12:29 AM   #5
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Does your car stumble at idle??To check the EGR Valve when the engine is at idle manually operate it and if the engine stumbles or stalls it is working right. Why the hell would a dipstick pop out due to EGR valve???
It is you PCV valve or you have excessive blowby.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 05-22-2005, 07:13 PM   #6
Pudula
update: i popped the hood after driving and when i pulled the dipstick out, there was air pressure in there. So my rings arent letting blowby and it's more likely the pcv valve right?
