Old 06-02-2005, 09:43 PM   #1
caall99
caall99's Avatar
caall99 is an unknown quantity at this point
Send a message via AIM to caall99
s13 Cruise control with SR20DET?
is it possible to have working cruise control with a SR20DET? my SR doesn't have the second mechanism on the throttle body for cruise control. can i swap throttle bodys (prefer not to)?
Signature over limits
http://www.zilvia.net/f/showthread.php?t=21036
caall99 is offline   Reply With Quote
Old 06-03-2005, 06:31 AM   #2
caall99
caall99's Avatar
anyone have any info regarding this? i want to know if i have to remove cruise control
Old 06-03-2005, 07:26 AM   #3
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
I think your best bet for cruise is to look at a FWD SR TB with cruis and see if it matches up otherwise you can always add aftermarket cruise and use stock buttons
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 06-03-2005, 07:40 AM   #4
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
um no....
if you take the throttle body off of a DOHC ka, and the cruise control linkage the only thing that you have to tackle is the wiring.
sepulchral is offline   Reply With Quote
Old 06-03-2005, 08:11 AM   #5
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
you can use a KA throttle body with the two pulleys on it for the cruise control
but i did that had it all hooked up and the actual electronic parts of the system didnt work. I think there may be some wiring you have to do.
rim_bender is offline   Reply With Quote
Old 06-03-2005, 10:52 AM   #6
PROJECTRB240SX
PROJECTRB240SX is an unknown quantity at this point
Swap The Tps Sensor Fromt He Sr To The Ka Throttle. I Know You Can Swap Sensors Between The Ka And Rb20 So I Don't See Why The Sr Would Be Different.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY!
PROJECTRB240SX is offline   Reply With Quote
Old 06-03-2005, 11:31 AM   #7
caall99
caall99's Avatar
Are the KA and SR throttle bodys the same size? i am talking about the inner diameter
Old 06-03-2005, 12:05 PM   #8
PROJECTRB240SX
I Believe So.... I Have Very Limited Experience With The Sr.
Old 06-03-2005, 09:38 PM   #9
caall99
caall99's Avatar
in case u guys were interested i decided to scrap the whole idea of keeping cruise control. Even though the TPS sensor looks like it can be swapped, i am still not sure if bolting it in at any angle will affect anything. It seems to me that the TPS sensor needs to be aligned just right.
Old 06-04-2005, 11:56 AM   #10
PROJECTRB240SX
just mark the ka tps sensor where the sr is..... and make sure when you swap it the sr sensor is where it was on the sr. That should give a good start point and then fine tune it. It should adjust your idle slightly and your acceleration ramp up (speed of response).
