Old 08-01-2005, 08:36 PM   #1
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
SR SAFC tune with new ARP head studs?
I just got my redtop reintalled in my S14 with ARP head studs and various other gaskets including head gasket. It was recommended to me to put around 1500 miles on the head studs keeping it under 5000 rpms and then retorque the head studs, change the oil etc. Does this sound normal?
Also, I have an SAFC II ready to go in the car, but to tune I would like to tune through the whole RPM band. Should I wait til after the retorque to tune or just tune the part I was recommended to drive in? Thanks for any input!
bshotts is offline   Reply With Quote
Old 08-02-2005, 11:14 AM   #2
bshotts
bshotts's Avatar
Any advice??
Old 08-02-2005, 02:04 PM   #3
BoostInnovations
BoostInnovations is an unknown quantity at this point
Send a message via AIM to BoostInnovations
if its on stock injectors you can just put the SAFCII in and set it up and then just make sure everything is zero'd out...technically you could prolly take about 5% off with stock boost...assuming you have an SR20...
BoostInnovations is offline   Reply With Quote
Old 08-02-2005, 02:44 PM   #4
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Maybe on low throttle settings but on high throttle settings you should be adding fuel down low. SR's run waaaaay too lean down low.
Flybert is offline   Reply With Quote
Old 08-02-2005, 03:35 PM   #5
BoostInnovations
really thats weird...that would probably explain why my car looks rich but smells lean...cause its lean at idle and just off i bet huh...
Old 08-02-2005, 03:51 PM   #6
bshotts
bshotts's Avatar
SR
So assuming it's running lean low in the rpms, should I try to give it an initial conservative tune up to 5000?
Also, my SR20 tends to run rich (at least it smells like it), so should I adjust for that?
Old 08-02-2005, 05:36 PM   #7
BoostInnovations
until you get it on a wideband i would keep it zero'd out...
