Old 09-11-2005, 12:32 PM   #1
Irving18m
Irving18m is an unknown quantity at this point
Send a message via AIM to Irving18m
Cleaning Guage Cluster Face?
My guage cluster plexi glass face has some spots on it and i have tried alot of stuff to try and get them off. They look something like water spots but i wipe them down and they disappear but once they dry they come back. Anyone have any household or good ideas? I tried goo gone and no luck. Thanks
Irving18m is offline   Reply With Quote
Old 09-11-2005, 02:53 PM   #2
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
It may be etching from some unknown substance.
Your best bet is Meguiar's Clear Plastic Cleaner and Polish. They're two small bottles, have the consistency of wax/polish...very nice stuff. I had a very visible surface scratch on the cluster when I first got the car. Since I've used the products, I've never seen it again, in any kind of lighting.
TurDz is offline   Reply With Quote
Old 09-11-2005, 04:09 PM   #3
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
at the vacuum stores around st louis they have a professional glass cleaner that i use on my windows, its called touch of glass (i used it when i cleaned up my gauge cluster, was really dirty)
it works great, its cool b/c it foams too...give it a try if you can find it, and if it doesnt work, then you have a kickass glass/window cleaner
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 09-11-2005, 05:11 PM   #4
projectRDM
projectRDM's Avatar
A new lens is less than $20. In the time it takes to try a lot of crazy chemicals to clean it you can just replace it.
FORMERLY R240NA
Old 09-11-2005, 09:51 PM   #5
Irving18m
$20 where? I spent about 30 mins just getting the face off the cluster with the whole removal and i know the guy at the junkyard knew i runied a perfectly good tach to get the face but its all i needed. And i will look for this Meguairs. Thanks
Old 09-11-2005, 11:31 PM   #6
projectRDM
projectRDM's Avatar
Well, new would mean from the dealer, unless your salvage yards sell new parts.
And if it took you 30 minutes to pull a cluster, you must have no arms, legs, and are blind.
FORMERLY R240NA
Old 09-12-2005, 09:47 AM   #7
Irving18m
Lets see, clear the space to get into the nasty car to have room to pull it, lower the steering wheel....looking for my 12mm deep socket. ok found it. 3 top screws then pull cluster out, then 2, then dash. OK EAT IT. Maybe 10 mins!
Ok so im not sure where to look for this stuff but I will look today at pepboys.
Old 09-11-2005, 07:02 PM   #8
TurDz
TurDz's Avatar
With Meguiar's plastic products (White and grey/green bottle), you can use it on your signal lenses, clear lenses, faded orange (chalky) tail lights, and anything else plastic that should be glossy. It's a great investment, and I highly recommend it.
Old 09-12-2005, 10:13 AM   #9
Irving18m
$49.96 for cluster face from nissan dealership....so not $20!
Old 09-12-2005, 11:38 AM   #10
projectRDM
projectRDM's Avatar
Your dealer is killing you.
FORMERLY R240NA
Old 09-12-2005, 12:44 PM   #11
kandyflip445
kandyflip445's Avatar
The plastic cleaner and polish work VERY GOOD. Though if you could get a new one for 20 then that would be the way to go.
My 240 vBgarage
Old 09-12-2005, 08:02 PM   #12
crioten
"buddy jesus"
crioten's Avatar
anyone know if the JDM hud cluster is the same as usdm one? and is this the same for the hud and non hud ones?
Old 09-12-2005, 09:01 PM   #13
projectRDM
projectRDM's Avatar
Cluster, or lens? The lens is of course.
FORMERLY R240NA
Old 09-13-2005, 12:09 AM   #14
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
used on polycarbonite material.... never use glass cleaner on plastic.. it doesnt work.... use this
infinitexsound is offline   Reply With Quote
