As the wheel turns...
I am trying to figure out if it is possible to run 17x10 fn01rc's on the back of an s14 that is lowered approx. 1" without doing more than rolling the fenders. And if so what offset is needed? I would like the edge of the rim not to stick out beyond the fender line.
![]() Join Date: Jan 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I can't give you exact offsets but almost positive 17x10 can fit with just rolled fenders.
I have 17x10 +10 on the rear of my S13. To fit I pulled my fenders about 15-20mm. Camber is around -1.5 Good luck, I'm sure someone else on here can give exact offsets for your 14. Billy
R35 GT-R, R32 GT-R, Supra, S13, S14, FD3S |
I'm running 17x10 +12 on the rear of my s14. the rim is sticking about an inch pass my fender line. I had to do a small roll and my car is dropped about 2 inches. I still need to drop it one more inch.
I would suggest getting +25 offset and using a 5mm spacer. It will get the wheels FLUSH to the fender and might clear coilovers. ![]()
![]() driftingisgay.com |
![]() Join Date: May 2003
If you want to run a tire that's appropriate for a 10" wheel (i.e., 255 as a MINIMUM)...then a 17X10, +35 will fit perfect. May require a *minor* roll from a rubber mallet, but that depends on camber.
- Brian
www.KA24DEvelopment.com |
#5 |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
i run 10 +20 on the s14 with about -1.3 degreess camber. fenders pulled slightly
235 (going 255 or 245 soon) 17" wheel nearly PERFECT with a fender roll and slight pull. but brian has the setup if you dont wan tto do either. |
