kei office coilovers question
I have the s13 coilovers on the s13 I have some weird clunking noise that is coming from one of the rear coils. I dont think the shock is blown there is nothing coming out of it and it seems to be coming off the pillow ball mount. I have put them in and taken them apart several times so dont tell me to tighten them down been there done that. I dont have the adjustment for the rear coilovers and I was wondering if it is set at 1 or 4 that this may be causing this noise. It only makes this noise on one of them I looked at the shock and didnt notice a bend in the rod. Also I switched the coilover to the other side and the noise switched sides so I know that this is where the noise is coming from. Any info would be great thanks jake
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
blown shock ibet
take of spring push shock down, piston should come back up slowly. if doesnt blown not 100% gaurantee shock is ok, but its the easiest way to check spring could be slapping coils but its most likely the shock. |
![]() Join Date: Apr 2005
check to see if something else is clunking in conjuction with it. Do you have RCAs, say if you were using single arm design, the coiulover might hit it, if you placed the RCA backwards.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! ![]() formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 ![]() |
problem is
he put the coilover on the other side and the side w/ the coilover in question made noise the other didnt switch them w/ same efffect its the coilover. |
#6 |
![]() Join Date: Nov 2004
If you don't have enough preload on the spring then it could be the spring slapping the top. Either that or it's bent but you said it isn't so~
#7 |
try spinning the lower perch the spring sits on towards the upper mount. to tighten the space b/w the spring and perches, its not necessarily preloading the coilover just eliminating gaps.
#8 |
I would say 80% that it's the spring. Make sure that it is seated and tight. It's always possible for it to work loose so make sure you check them from time to time.
