Trouble with a rusted hex nut. Need advice.
This is truly a beginner's moment... =-(
Trying to unmount front sway bar. In the process, I striped one of the hex nut holding the sway bar... Drives me nuts. It is completely stripped and stuck there. Is there any way I can get this off? |
I had the same problem happen with one of the bolts for the rear suspension. I just used a cut-off wheel to remove and replaced them with grade8 nuts and bolts -way stronger than factory bolts anyway. If you don't have a cut off wheel you can also use a chisel to split the nut and free the bolt. Unfortunately, either method will require the replace of the nut and most likely bolt too.
back at it again.... |
I had this exact problem when i replaced my front sway. There is a special set of sockets made to grab rounded off nuts, but I think they're very expensive. (My Dad is a nissan master tech, has a set of em.) What sways are you using? The ST sways come with new bolts, but you will need new nuts.
'93 Pathfinder SE daily driver '93 HB blue (under construction) '89 Celica GTS RIP |
#5 | |
#6 |
![]() Join Date: Sep 2002
You can use a chisel and hammer straight into the nut to make an indention. Then angle the chisel in the indention so that when you strike it it will take the nut off. I've used this to get some crazy stuck on bolts on some Dodge transmissions.
My 240 vBgarage |
#8 |
![]() Join Date: Sep 2004
Everybody's pretty right, worst case senario if you don't want to spend any money then use the vice grips. But there are tools made for this. You can go to Sears and pick up the craftsman version for not too much money. It looks like a socket but inside it has spiral sparp grooves in a clockwise direction. You can buy the individual size or a set of four or five. Ask the dude at the counter they'll know what it is. When you turn the bolt off using it, it grabs into the bolt and pulls it out. Trust me it's better to get that tool because I promise you it won't be the last time you'll use it.
#9 | |
![]() Join Date: Mar 2003
i <3 my bolt out. |
#10 | |
Fits to 1/2 drive and has left hand bound spiral grooves. Don't know how to use this yet. Should I use this air tool instead of socket wrenches in my hand? |
#11 | |
put it on the bolt. turn it a little counterclockwise so it locks onto the bolt. now put your breaker bar in there and turn as hard as you can. these spiral sockets do not strip. rather, they will dig grooves into the bolt and hold on for dear life. |
#12 |
It would be better to use the socket or a breaker bar like he said cause it's more precise. If you use the impact gun you might slip off and mess up the whole thing. Just get it on, slowly turn and lock onto the bolt, then take the ratchet or breaker bar and turn it right off.
#13 | |
I thought I was to turn it clockwise to lock it on the bolt then turn counterclockwise to unscrew... BTW How is WB40 compared to PB Blaster? |
#15 |
I remember a tv show saying that WD-40 was originally made to PREVENT the formation of rust on missiles or something.
My 240 vBgarage |
