Old 09-26-2005, 09:39 AM   #1
Kyo Kusanagi
Kyo Kusanagi's Avatar
Kyo Kusanagi is a well-known jackass
Send a message via AIM to Kyo Kusanagi
Gear Crunching?
From First to 2nd the gears are fine, when i try to shift into third it always either crunches and sometimes it grinds. Also sometimes 4th gets a lil bit crunchy is my clutch going out?
Kyo Kusanagi is offline   Reply With Quote
Old 09-26-2005, 09:47 AM   #2
aznpoopy
aznpoopy's Avatar
3rd & 4th gear synchros
aznpoopy is offline   Reply With Quote
Old 09-26-2005, 10:36 AM   #3
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
+1 your syncros are probably finished
smily_vigor is offline   Reply With Quote
Old 09-26-2005, 12:12 PM   #4
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
anyone sell tranny rebuild kits on the forum... mines the same... and on the 2 to 1 downshift...
TheWolf is offline   Reply With Quote
Old 09-26-2005, 12:16 PM   #5
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
It's cheaper to replace the whole trans with a used one...they are $250-300, versus +$1000 for a rebuild.
Search for one near you: www.car-part.com
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 09-26-2005, 12:42 PM   #6
TheWolf
TheWolf's Avatar
I'd rather not go "used" and just rebuild mine. Mine was "good used" till it started grinding...
Old 09-26-2005, 04:48 PM   #7
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
Double Clutch then...hehe
TurDz is offline   Reply With Quote
Old 09-26-2005, 04:56 PM   #8
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
Be glad its just 3rd and 4th for you. ALL the syncros in my KA trans are shot. Grinds every hard shift, every time. Good thing I've got that SR just waiting for some cash to be thrown at it before I install it.
'93 Pathfinder SE daily driver
'93 HB blue (under construction)
'89 Celica GTS RIP
SHIFT_control is offline   Reply With Quote
Old 09-27-2005, 11:10 AM   #9
Kyo Kusanagi
okay so its my syncros, so is it better getting a new clutch or a new tranny. Also my car squeaks and i think its the bushings?
Old 09-27-2005, 11:37 AM   #10
orion::S14
orion::S14's Avatar
Only reason I suggest used is cost...you could buy a ~20,000 mile-old, perfect condition used trans for $400, versus $1000 for a rebuild...hell, even if that 1st used trans started to grind after a few years, you could buy another and still be $200 ahead.
BTW, what fluid are you using?
You clutch isn't causing your gears to grind, unless it's improperly adjusted...it's sychros most likely, and to fix that you'll need a new trans.
- Brian
Old 09-27-2005, 12:02 PM   #11
TheWolf
TheWolf's Avatar
I'm so used to tranny parts costing so little, a full kit for my 300zx is like $190.. and $400 for a ae86 one.. pricing out one for the tranny on my ka24 was like "whoa".. I'll eventually go sr20 so I guess I'll live with it... I'm also using mobil 1 fluid...the car was drifted before I got it so i'd say it's been pretty beat on...
Old 09-27-2005, 06:21 PM   #12
orion::S14
orion::S14's Avatar
FYI...Mobil 1 fluid is GL4/GL5...so it's BAD for KA/SR transmisisons.
You need a GL4 ONLY fluid...if it also meets GL5, then it's not for you.
Redline is best, try MT90.
(Reason: GL5 has an additive that, combined with water (condensation) will corrode your brass sychros)
- Brian
Old 09-27-2005, 07:53 PM   #13
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
yeah redline gear oil is best..... ive never had an issue with grindin 3rd after i switched over.....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 09-27-2005, 09:31 PM   #14
TurDz
TurDz's Avatar
I have...it will only help somewhat. MT-90 turns to thin liquid on the track...
Old 09-27-2005, 10:11 PM   #15
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
check the fluid in the clutch master cylinder. I had this same problem when my slave cylinder started leaking and eventually puked. If it is bad, when you change it make sure you take the closed loop box out of the clutch line when you do, takes 10 mins and makes the clutch feel that much more positive.
undercoverdjay is offline   Reply With Quote
Old 09-27-2005, 11:45 PM   #16
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
i used redline heavy shockproof, it helped alot, no more grind,
but after several months it came back
Wei240 is offline   Reply With Quote
Old 09-28-2005, 12:18 AM   #17
smily_vigor
There's already been a thread with pretty much this same topic. Most guys in there are using Redline or this other one. Do a search under tranny fluid, actually it might also be in the chat section. It's late so my brain isn't working too well to remember exactly where it is. Anyways it's between Redline and this other one called Gm sycromesh but not any symcromesh it had a special feature or additive. Also another guy mentioned a pennsoil syncromesh, well ya'll get the point search for the thread to get the exact names.
