Old 09-27-2005, 03:33 PM   #1
xagna
xagna has a little shameless behavior in the past
too less caster, no good?
After installing a set of spl t/c rods, I have been trying different adjustments.
I came to decrease the caster to 5 degrees from the stock angle. Now handling is feather light and I like this although high speed cruising is a little unstable.
My question is if this too little caster would stress other suspension components or the t/c rod itself and damage them. Will it?
xagna is offline   Reply With Quote
Old 09-28-2005, 09:44 AM   #2
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
do the rods even have provisions to decrease your caster 5 degrees???? decreasing your caster will decrease driver effort turning the wheel under hard driving situations however it will also have a very large negative impact on your cars overall handling. high speed cruising is one of them or even just whipping around corners. personally I run 9 degrees caster in my car and it makes the wheel snap back more when whipping around and fight me a little bit but it increases stability and handling substantially. why you would ever want to install something like that and run your car that way is beyond me. I doubt running your car that way will cause any extra stress on your components and you would probabbly be fine.
tastyratz is offline   Reply With Quote
