Old 09-27-2005, 07:29 PM   #1
ladyinred
ladyinred is an unknown quantity at this point
Can't Get the Darn thing Off!
I'm trying to remove injector #4 without stripping the bolts but they're in there pretty tight.. I sprayed some PB Blaster and I'm gonna let them soak until tomorrow, but just in case that still doesn't do the job, anyone have any tips on a better way of getting them off?
Thanks
::1992 Green 240SX HB::
my cardomain
ladyinred is offline   Reply With Quote
Old 09-27-2005, 07:41 PM   #2
projectRDM
projectRDM's Avatar
Impact screwdriver. Once you get the screws out, go buy some M5 machine screws (IIRC) to put back in, you'll never have to worry about it again.
FORMERLY R240NA
Old 09-27-2005, 08:22 PM   #3
ladyinred
Great, I'll do that... where can I find those screws? local hardware shop? THANKS
my cardomain
Old 09-27-2005, 08:47 PM   #4
aznpoopy
aznpoopy's Avatar
yeah... where can you get those?
i was sweating my balls off trying to take those fuckers out without stripping the phillips head.
edit: btw i found grips to work real well if you happen to strip it by accident.
aznpoopy is offline   Reply With Quote
Old 09-27-2005, 09:51 PM   #5
projectRDM
projectRDM's Avatar
Take one to a good hardware store and match it up per the threads, or take the whole rail in.
FORMERLY R240NA
Old 09-28-2005, 02:03 AM   #6
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
VISE GRIPS!!!!!
lol i've had fuel injector problems and been replacing mine like crazy, it's all good now, friend told me to use vise grip around the screws, damn why didn't i think of that earlier, so much easier, gets it off like nothing, once i got each lose jus used a screw driver, easy
Indolent is offline   Reply With Quote
Old 09-28-2005, 04:41 PM   #7
WideS13
WideS13 is an unknown quantity at this point
Try NAPA for the new hardware. They usally have large shelf type displays that have all diffrent kind of thread pitch ans size bolts. They have always had what I was looking for and then some. You should replace them with ones that have hex key heads.
WideS13 is offline   Reply With Quote
Old 09-28-2005, 05:17 PM   #8
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
I just went through the same thing. I used needle nose vise grips, then replaced the screws with normal bolts. Much better now! As big a PITA as those little screws where, nothing like getting the injectors themselvs out! Anyone have any tips on how go get injectors out of the rail without damaging the injector tops?
SpeedMonkeyInc is offline   Reply With Quote
Old 09-28-2005, 06:25 PM   #9
aznpoopy
aznpoopy's Avatar
use two wide flat screwdrivers and pry them out. if you are really anal you can wrap the tip with some tissue paper or rubber bands.
Old 09-28-2005, 06:33 PM   #10
projectRDM
projectRDM's Avatar
Hose pliers rule for pulling injectors.
FORMERLY R240NA
Old 09-28-2005, 08:41 PM   #11
ladyinred
thanks for all the help... now once i have them off, I need to replace the injector! LOL.. anyone have a good working injector for sale??
Originally Posted by Indolent
VISE GRIPS!!!!!
Indolent: So, replacing the injector solved your problem? I read your past threads and I'm having a very similar problem with my #4 injector as you had with yours.. I've already done the compression test, checked the plugs for sparks, checked resistance, isolated the problem to injector#4, and just seafoamed my gas tank, crank case, and intake mani to see if it may be a clogged injector... But now i'm looking to just go ahead and replace it..
my cardomain
Old 09-28-2005, 11:49 PM   #12
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
http://www.sears.com/sr/javasr/produ...pecialty+Tools
THE best tool in my roll-away, actually its the second best tool, because its useless without
http://www.sears.com/sr/javasr/produ...id=00938395000 any hammer will do, but the uses of the big boys are infinite. :hammer: :hammer: :hammer:
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
