Old 09-29-2005, 07:49 AM   #1
two4tee
two4tee's Avatar
two4tee is an unknown quantity at this point
Going Staggered what tires should I use?
I am planning on going either 16x7 and 16x8 or 17x7 and17x8, what size of tires should I use on the 16 or 17?
two4tee is offline   Reply With Quote
Old 09-29-2005, 11:24 AM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
205/55R16 and 225/50R16 or 205/50R17 and 225/45R17
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 09-29-2005, 02:12 PM   #3
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
why would you use a 17x7 wheel? why not 17x8 and 17x9. what offset are the wheels?
DP_Michelle G is offline   Reply With Quote
Old 09-29-2005, 07:43 PM   #4
two4tee
two4tee's Avatar
Longchamp xr48 with offset of +38 or Sparco with offset of +41 in the front and +45 in the rear
Old 09-29-2005, 08:20 PM   #5
DP_Michelle G
are you sure you want to run those offsets on your s13. you should check out the wheel threads on here.
Old 09-29-2005, 08:22 PM   #6
HyperTek
i wouldnt run too much of a tire stagger unless you want to combat with understeer.. At least try to keep them simular.
Keep it Classy
