Old 10-12-2005, 09:21 AM   #1
dreamer
dreamer is an unknown quantity at this point
installed new h2o pump, now she wont run
i put a new water pump in my car, 91 motor in a 90 chassi. started her up to circulate the coolant through the system... and it starts at 1500 rpm, then 5 seconds later drops to 900 rpm, 5 seconds later drops to 500rpm, then stalls. this happens every time i start it. everything seems to be plugged up (sensors, vacuum lines) any advice?
dreamer is offline   Reply With Quote
Old 10-13-2005, 07:02 AM   #2
cotbu
cotbu's Avatar
I'll assume you know how to add coolant and bleed it.
So
Q1 Did the temp rise higher than normal?
Q2 Did it run long enough to reach operating Temp?
Check battery and alternator
If it fluctuated rpm like 1500 900 1500 900 ect then maybe it's the coolant temp sensor or your overheating because your pump isn't working.
but just dying out maybe it's the battery.
Old 10-13-2005, 09:55 AM   #3
dreamer
battery is new, yes i know how to bleed coolant, the temp did not rise. it did reach operating temp because i kept tugging on the throttle and it kept it alive. i dont see why the pump wouldnt work because its brand new, and i tested to make sure the parts move before i put it in. its not an overheating issue, i'm pretty sure... although the car has overheated before, hence the need for a new water pump. but it ran fine before i took it apart to put the new water pump in.
the water pump was leaking at the seams, it did not break, so i just filled it back up with coolant and drove it around the neighborhood, so even after the car had overheated, i know that it ran just as well as it did before it overheated... so i must have fucked something up with the install?
if you move the belts around thats connected to p/s and water pump and all that, can you mess up the timing? i dont think so, but it could be another possibility
Old 10-13-2005, 01:00 PM   #4
cotbu
cotbu's Avatar
Never seen that happend but it's always a possibility but why i don't think you through off the timing is becuase it's set internally by a chain or belt. if you were replacing your cams then yeah it's a major possibility.
Also how long did the car sit before you replaced the pump. I wanna help you but i keep reading the post over and it makes me feel like it's you battery or electrical maybe even a sensor. Is the Idle smooth but erratic?(like 20 seconds or so at 1500 then drops)
Try a different battery then post what happens.
Old 10-13-2005, 09:39 PM   #5
dreamer
i think i know what it is.... when the rain stops (lord knows when that will be) im gunna loosen up the belt a little. i think i overtightened/overtorqued it
i didnt know anything about belts, i thought they were supposed to be really tight then my mechanic said that if i dont torque it, i should be able to grab the belt and twist it 90 degrees... .....i cant even twist it 10 degrees
Old 10-13-2005, 10:49 PM   #6
projectRDM
projectRDM's Avatar
Bingo. Hopefully you didn't warp a pulley in the process.
FORMERLY R240NA
Old 10-14-2005, 03:41 AM   #7
cotbu
cotbu's Avatar
Let us know what happens...
Later Chief
Old 10-14-2005, 01:26 PM   #8
dreamer
well... i loosened it to 90 degrees and it was basically falling off... so i tightened it a little... probably to like 65 degrees-ish. still stalls...and now my power steering is erratic... like when i turn the wheel, its easy, then harder, then easy, then harder... i would assume this is because the belt is too loose, no?
this next pic is the belt while the car is running.... is it supposed to arc out like that on the left? or is it supposed to be straight/pulled tighter?
i also found 2 vacuum lines that arent connected to anything... i dont know what they would connect to though.
the 2 small ones under the upper radiator hose. where do they go?
sigh...i feel like this should be so easy but i just suck at life
Old 10-14-2005, 01:33 PM   #9
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
aren't there supposed to be two lines/holes around the top radiator.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 10-14-2005, 09:19 PM   #10
dreamer
i didnt see any but ill take a closer look tomorrow... anyone know where i can find vacuum diagrams?
Old 10-14-2005, 09:49 PM   #11
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
um, i see a very big problem in that picture...u didnt attach the hole in the bottom of the stock intake to that resonator box thats down there, thus inducing a massive leak in ur intake
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 10-15-2005, 01:11 AM   #12
dreamer
when the car was running it was connected. i took it out to make some room to take more clear pics
Old 10-15-2005, 08:40 AM   #13
240Driver39
haha, alright, just checking
Old 10-15-2005, 06:23 PM   #14
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
sounds like vacuum leak to me
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 10-16-2005, 01:58 AM   #15
omgosh
omgosh is an unknown quantity at this point
Those 2 hoses have something to do with the charcoal cannister...I think one comes from the gas tank to the cannister and one goes from the cannister to the intake mani...there is a diagram in the FSM.
And the belt...I dont know anything about belts either but Im pretty sure the "twisting 90*" part means looking at the front of the motor you would twist the belt foward to back. There is definately not supposed to be that much slack in it.
omgosh is offline   Reply With Quote
Old 10-16-2005, 11:00 AM   #16
dreamer
lol yeah i figured that out... he was like "TWIST! NOT PINCH AND TWIST!" ... where is this diagram in the FSM because i cant find it... i have it in pdf form and i swear it doesnt seem to be anywhere...
Old 10-19-2005, 11:34 PM   #17
omgosh
Its under the emissions and electronic control or something section if you havent found it yet..
Old 10-21-2005, 03:50 PM   #18
dreamer
sigh... i woke up today and found 4 tickets on her. i hate my life.
Old 10-21-2005, 04:03 PM   #19
m0rex
m0rex's Avatar
m0rex is on a distinguished road
Dude just connect all the hoses how they went. Its gonna be around the intake area.
m0rex is offline   Reply With Quote
Old 10-21-2005, 10:38 PM   #20
dreamer
everything that i can see is hooked up. i dont see anything loose that would connect to the hoses i found. i looked at the vacuum diagram and it looks like there are hoses that are supposed to be there that i never had at all... but didnt have trouble with it before? i dunno... strange. ill just take it to a shop, pay too much, but at least have it fixed.
