Old 10-18-2005, 03:10 PM   #1
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
SR sr20det FLYWHEEL FUN!!!!!!!!!
So after all the banging away at the key board at retail sites, phone calls and one trip to the Vons produce dept scale, here's the results...
NOTE: This is for sr20det s13/s14 flywheels ONLY, and please correct me if I'm wrong about any of the measurements (weights will vary a bit).
prostreetonline.com-------------8.87lbs.--------------------steel
XAT prolight--------------------10lbs.----------------------chromoly
Toda---------------------------10.56lbs.-------------------chromoly
Cusco--------------------------10.56lbs.-------------------chromoly
JGY.com------------------------10.41lbs.-------------------chromoly
Fidanza-------------------------11lbs.----------------------aluminum
Aasco--------------------------12lbs.----------------------aluminum
JUN-----------------------------12.3lbs.--------------------chromoly
Exedy---------------------------13.91lbs.-------------------chromoly
XAT streetlight------------------14.1lbs.---------------------chromoly
SPEC---------------------------15lbs.------------------------billet
STOCK FLYWHEEL WEIGHT WAS 19.9LBS. (thanks Vons produce dept!)
A good rule of thumb is to +/- 0.5lbs. TO 19.9lbs. that I got. I hope this saves some sorry schmuck the hassle I went through to try to pick the right flywheel. HAPPY MOTORING!
s13coupedrfter is offline   Reply With Quote
