Building Block...
Okay I am about to have the block done in my SR20DET. I have most of the basic bolt-ons, and I know no fear of my current turbo blowing it up, but I want to have the block done before I ever need it built, so I wont have to worry about it and I know everything is in good order. Anyway, here is my shopping list right now, I am going to get oem bearings (main-rod) after I find out the grade, and might have to order some more parts after I get the block apart (valve might be burned or something). I want it to be a nice solid build, good for about 450-500hp. Like I said, my turbo now will probably only kick out 250hp at full psi. After I do this build I will start looking into new turbos, probably a Greddy GT2540R. Anyway, if some of you that have done this before can look at my list, tell me what you think/recommend, I would greatly appreciate it!!! Also getting the head P&P while off.
*APEX'i Metal Headgasket 86/1.5mm* Replaced With APEX'i Metal Headgasket 86/1.2mm *HKS Valve Springs & Crower Titanium Retainer Kit* Replaced With Ferrea Valve Spring, Titanium Retainers, and Valve Spring Locators. *HKS Rocker Arm Stopper Kit* Replaced With Greddy Rocker Arm Stopper Kit (Cheaper) Tomei Valve Guides *Eagle Rods* Replaced With Stock Rods ARP Headstud Kit ARP Rod Bolts CP Pistons 86.5mm/8:5:1 Pro Fab Design Intake Manifold Gasket Engine Gasket Kit Some maintence stuff im going to replace, already got new water pump and oil pump/timing chain cover Timing Chain Tensioner Timing Chain PCV Valve TPS Sensor Last edited by Gutling; 10-20-2005 at 02:50 PM.. |
