Old 11-17-2005, 06:35 PM   #1
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
what controls camber??
I have a lightly modified s13 (front suspension: d2coilovers/ tein tie-rods/ tension rods)and am having some front camber issues. I know my rack and pinion is shot and needs to be replaced, but does anything else other than the front camber plates control camber? The reason I ask is because when I set my camber, my driver side (when the plate is max'd out) used to be over -4degrees. Now when I max the plate out, i only get to about -1degree. What else could be moving/sliding out of place that would throw off my camber (the camber plate doesnt slide,it stays where I put it)? Any help is appreciated- Rob
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 11-17-2005, 09:44 PM   #2
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
lower control arm pivots from the mounting point, as you lower the car the control arm gets closer to paralel with the road. as this happens distance between the frame, and the ball joint increases, but the strut mount remains the same. this causes negative camber. where the strut bolts onto the spindle there is some adjustment, and camber plates on top of the spring shock/coilover can move the top in or out more to adjust camber more.
draw it all out on paper, and you should be able to figure it out. Unless you ditched class too much in high school.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 11-18-2005, 12:22 AM   #3
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
yeah, that's pretty much it. roll-center adjustment is key here. also, if you would like dynamic camber, messing with the caster would be a good idea also
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 11-18-2005, 12:26 AM   #4
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Or how about those camber bolts on the macpherson mounts on the coilovers?
Those are always good.
SochBAT is offline   Reply With Quote
Old 11-18-2005, 12:36 AM   #5
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
and make sure your lca's not bent, or anything else for that matter.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 11-18-2005, 06:58 PM   #6
nlzmo400r
well nothings bent, I figured it was my ball joints on the lower arms. Also, ive messed with the strut mounting bolts on the shocks, didnt do enough. I'll take a look at it again on paper and see what I can do. I know my alignments dont hold because my rack and pinion is fucked up, so its hard to tell if my camber stays at one point (unless it goes so far out of whack that I can eyeball it)
