Brake caliper leaking. Need advice.
![]() As you see in the picture, I have a leak. I guess that the seal is broken. Do you think I should just change the seal or put a new caliper in? I do have spare set of calipers. If I have to install a new caliper, how can I undo that part in yellow circle in the picture below? It is a parking brake line stay. What tool do I need and can I yank it out without power assist? ![]() |
No more nissan.
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Replace the caliper with your back up, then replace the seal. That way you still have good back ups.
And you unbolt the lines, then you can pull out the e-brake cable using the free slack.
No more nissan.
LOL.. it's not a tool. Once you unbolt the line, you'll have room to pull the cable in and slip it through the holder in the line.
#5 | |
So you are saying that when I unbolt the fixture that keeps parking brake tight on the caliper, the parking brake cable will be loose enough slip out othe holder, right? |
