Old 08-28-2002, 10:01 PM   #1
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
Ok, I'm starting to buy stuff (rods are already on their way). &nbsp;I'm hoping to have everything together and planned by the end of October...and the better I get everything sorted before then, the less down time I'm likely to have with the car. &nbsp;So here's my list of parts. &nbsp;I think I got everything covered to have a safe turbo system, boosting initially at 8psi (upgrades will come soon...shooting for 320+hp to the wheels <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> ) &nbsp;So if you kind Zilvians can lend your scrutiny I'd be very grateful. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Engine Rebuild:
-Arias pistons 8.5:1 (including pins, rings, and locks)
-Crower rods
-timing assembly rebuild (chains, guides, etc.)
-any required shaving/boring of head/cylinders for flatness/roundness
-all gaskets/seals
Turbo/Accessories:
-T3/04 Turbonetics Turbo (trim and a/r yet to be settled on)
-RevHard Manifold ("warmed over" by yours truely to avoid the notorious cracking)
-Tial 35mm wastegate (7-8psi)
-muffler shop 3" down/mid pipe
-recirculating BOV (maybe SSQV)
-water/oil lines and fittings
-Autometer -30mmHg/30psi boost gauge
Air Intake Track:
-K&N or equivalent cone filter
-3" filter-to-turbo muffler shop piping
-2.5" muffler shop intercooler piping
-Audi 5000 or some other adequately sized junk yard intercooler
-silicon hose/fittings/clamps
-battery relocation kit
Fuel System/Management:
-300ZX Fuel Pump
-370cc Injectors
-JWT ecu
Clutch:
-ACT 4puck (any more streetable alternatives for 300ft.-lbs.+?)
So, is that everything? &nbsp;Any suggestions?
thanks!
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
LanceS13 is offline
Old 08-28-2002, 10:29 PM   #2
LanceS13
AutoX Junkie
Look under Air Intake Track...Audi 9000, Starion, or whatever I can find big enough and in decent condition junk yard intercooler.
BTW, what wing is that on your car?
It's the fuel part I'm not for sure about. &nbsp;Do I need to upgrade the fuel pressure regulator? &nbsp;Will the stock fuel rail accept 370cc injectors?
LanceS13 is offline
Old 08-28-2002, 11:50 PM   #3
Alias
Alias is an unknown quantity at this point
How much is that costing you? I would get bigger injectors. Its seems like everyone gets the turbo bug and cranks it up. Don't wanna run lean <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Alias is offline
Old 08-29-2002, 06:05 AM   #4
thewholefnshow
thewholefnshow is an unknown quantity at this point
Send a message via ICQ to thewholefnshow
I would get a turbo temperature gauge and more importantly an air/fuel gauge, worry about the injectors if you notice you are running lean (or on the lean side) during wide open throttle. Plus then when you do play with boost you always know how much gas yo uare getting to the engine.... save the money for the injectors till you are sure you need em. I mean... for when you get bored and wanna crank the boost up... cause of course eventually you will need them &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
thewholefnshow is offline
Old 08-29-2002, 08:29 AM   #5
LanceS13
AutoX Junkie
Alias, I have $6K budgeted and an additional $2K backup/emergency. But I'm guessing $5500 or so if all goes well.
And good idea on the extra gauges. Where would you mount a turbo temp gauge sensor/sender, and what's safe operating temps?
And I know the 370cc injectors aren't good for 320+hp, but from what I understand, they fit the stock fuel rail...and anything bigger requires a custom fuel rail (is this true?). Even larger injectors and custom fuel rail are part of "Stage 2" at the moment.
LanceS13 is offline
Old 08-29-2002, 11:47 AM   #6
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
320rwhp w/ 370cc &nbsp;injectors? need 50lbs.
you do need a custom fuel rail also
as for the block, since u have it out, get it o-ringed. you will never have to worry about a blown head gasket. are u boring the cyclinders? or did you get stock bore pistons.
also get the crank balanced and knife edged. go for nismo bearings, and get the journals custom cut
as for fuel regulator. u dont need one because the JWT fuel setup covers it. but runs a little rich. the fuel regulator is great on the dyno which you can adjust the fuel pressure to make the airfuel ratio perfect for the best horsepower.
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline
Old 08-29-2002, 12:42 PM   #7
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">320rwhp w/ 370cc &nbsp;injectors? need 50lbs.
</td></tr></table><span id='postcolor'>
No...about 250hp initially. &nbsp;370cc injectors for now if they fit the stock fuel rail. &nbsp;(Do they?) &nbsp;I'll upgrade to 50lb./custotm fuel rail later when I get some more money saved up. &nbsp;However, if the 370cc injectors don't fit the stock fuel rail, I'll go ahead and get the bigger injectors &nbsp;and custom rail.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">as for the block, since u have it out, get it o-ringed. you will never have to worry about a blown head gasket. are u boring the cyclinders? or did you get stock bore pistons.
How much can I expect to spend on getting it o-ringed?
Pistons have yet to be ordered. &nbsp;I'm gonna wait until I can look at the cylinder walls and see if they require boring to round them out or smooth them up. &nbsp;If so, it will be minimal.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">also get the crank balanced and knife edged. go for nismo bearings, and get the journals custom cut
whoa now...only got $6K budgeted remember. &nbsp;That sounds like some major cash. &nbsp;I wouldn't think it would require all that when there's guys out there running 300hp on completely stock internals/bottom. &nbsp;How much would all that cost?
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">as for fuel regulator. u dont need one because the JWT fuel setup covers it. but runs a little rich. the fuel regulator is great on the dyno which you can adjust the fuel pressure to make the airfuel ratio perfect for the best horsepower.</td></tr></table><span id='postcolor'>
So I'm assuming the JWT setup is versatile enough to let me run a little rich w/o one, but can still install an adjustable one later when I get ready to dyno tune.
If you haven't noticed, I'm trying make this as cheap as possible w/o taking any detrimental shortcuts. &nbsp;I'd like to have enough left over to do a front Z brake upgrade to help me control the extra power. &nbsp;When I'm done with it, I'd like to have it running safely around 250hp to the wheels, but fairly easily be able to attain my power goal with a little more time/and money over the next year or so. &nbsp;What do you think?
thanks
LanceS13 is offline
Old 08-29-2002, 02:55 PM   #8
boosteds14
boosteds14's Avatar
the 370cc injectors are the exact injectors used in the 300z
they drop right into the fuel rail.
ok, scratch the crank thing. the o-ringing i guess is pretty cheap. here is an example of what i paid
ALL FOR $500>>
block o-ringed
slight bore
polished crank,
balanced crank
bearings
block decked
lower timing cover decked to match the block height
lower timing cover and upper timing cover powerdercoated
rear and front main seals put in
and assembly of the bottom end.
240SXONE
Old 08-29-2002, 05:49 PM   #9
adey
adey's Avatar
I don't know if thewholefnshow was referring to an EGT gauge or if there's such thing as a 'turbo temperature' gauge... but an EGT would be useful as well as an oil pressure and air/fuel ratio gauges. If you could only get one it would be either EGT or Oil press. &nbsp; ... actually, all 3 are pretty important for boosted cars... errr... but anyway. Your budget will decide what's "needed". <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Instagram: @SX180HKG
adey is offline
Old 08-29-2002, 07:37 PM   #10
LanceS13
AutoX Junkie
Well, gauges are fairly cheap compared to some of the other things I'm paying for, so I could probably spring for an extra gauge or three (if I can only figure out where to put them--not real fond of A-pillar pods). &nbsp;
I figured he meant exhaust gas temp...never heard of turbo temp. &nbsp;Would the egt just be tapped into the down pipe? &nbsp;the header?
I'm also open to any suggestions regarding effective engine bay heat management.
LanceS13 is offline
Old 08-29-2002, 08:20 PM   #11
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
I'd say get a walbro fuel pump instead of zx one. Don't think it would matter much, but i heard it's better, plus those 50-60 bux of difference won't really matter assuming u'll spend 6 grand
кто болеет за Зенит, у того всегда стоит!
Kreator is offline
Old 08-29-2002, 08:36 PM   #12
LanceS13
AutoX Junkie
I was thinking about going with the Walbro, depending on price and how much was left in the budget (since that'll probably be one of the last things to go in). &nbsp;For the Walbro replacement, is the right size 255 l/hr?
LanceS13 is offline
Old 08-29-2002, 09:36 PM   #13
negular
Dr. Neg
negular's Avatar
negular is an unknown quantity at this point
Send a message via AIM to negular Send a message via Yahoo to negular
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">-RevHard Manifold ("warmed over" by yours truely to avoid the notorious cracking)</td></tr></table><span id='postcolor'>
how do u do this?
The louder the radio, the better I sing.
negular is offline
Old 08-29-2002, 10:10 PM   #14
LanceS13
AutoX Junkie
I'm trying to figure out a way to put slots between each runner and increase the bolt hole sizes as they go from center to edges. &nbsp;This should allow room for thermal expansion and keep it from cracking.
LanceS13 is offline
Old 08-29-2002, 10:18 PM   #15
fodive
fodive's Avatar
fodive is an unknown quantity at this point
in an attemp to awnser you guage qeustion, but if you have that little tray under you stereo, you could probably fit a couple of gauges there, like boost and a/f, which i thik are the two most important, or you could always tuke them away in the glove box if you want the car to still look stock, just some ideas, hope they help, sorry i cant help on the turbo parts tho, i need to learn more about that b4 i go KA-T
roots.
fodive is offline
Old 08-30-2002, 09:39 AM   #16
uiuc240
uiuc240's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (LanceS13 @ Aug. 28 2002,11:29)</td></tr><tr><td id="QUOTE">Look under Air Intake Track...Audi 9000, Starion, or whatever I can find big enough and in decent condition junk yard intercooler.
It's the fuel part I'm not for sure about. Do I need to upgrade the fuel pressure regulator? Will the stock fuel rail accept 370cc injectors?</td></tr></table><span id='postcolor'>
you're going with some NICE parts but you're going to get a junkyard intercooler? &nbsp;one that you have no idea whether or not it has leaks or if it's plugged in spots? &nbsp;my vote goes to a nice FMIC...since you're obviously not doing the CHEAP route on other stuff.
the walbro 255 will be cheaper and better than the Z pump, BTW.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline
Old 08-30-2002, 10:28 AM   #17
boosteds14
boosteds14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">I'm trying to figure out a way to put slots between each runner and increase the bolt hole sizes as they go from center to edges. &nbsp;This should allow room for thermal expansion and keep it from cracking.</td></tr></table><span id='postcolor'>
good idea <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
and another thing about the revhard is that it causes the bolts to unloose because the design. from what i hear
240SXONE
Old 08-30-2002, 10:33 AM   #18
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">you're going with some NICE parts but you're going to get a junkyard intercooler? &nbsp;one that you have no idea whether or not it has leaks or if it's plugged in spots? &nbsp;my vote goes to a nice FMIC...since you're obviously not doing the CHEAP route on other stuff.
Well, if I do go that route, I will have it pressure tested...but I guess that's still letting a nickel hold up a dollar. I definitely can't afford to drop $800 on an intercooler kit. I've recently heard that f-max has a kit for a little over $400, which I'm looking into. And I think daperformance.com sells a huge intercooler (no kit) for a little over $300.
(BTW, thanks everybody for answering all these questions and giving all these suggestions...this will be great FAQ/Archives material when we're done with it. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> )
LanceS13 is offline
Old 08-30-2002, 10:39 AM   #19
uiuc240
uiuc240's Avatar
There's also the Isuzu NPR FMIC that people talk about. &nbsp;You could also look for newish Spearco FMICs on eBay and around the internet. &nbsp;I agree that you probably don't need a "kit" as you can do fine with custom piping. &nbsp;I just think the junkyard IC sounds like a bad idea...who knows what could have fallen in there or plugged up stuff. &nbsp;And it might hold pressure and work just fine...until the rat droppings get jarred loose after 500 miles and get sucked into your engined only to be chewed up by your throttle plate, valves, and turbine. &nbsp;Sucky.
Eric
2002 Mazda Protege5
uiuc240 is offline
Old 08-30-2002, 10:41 AM   #20
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (boosteds14 @ Aug. 30 2002,11:28)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">I'm trying to figure out a way to put slots between each runner and increase the bolt hole sizes as they go from center to edges. This should allow room for thermal expansion and keep it from cracking.</td></tr></table><span id='postcolor'>
good idea <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
and another thing about the revhard is that it causes the bolts to unloose because the design. from what i hear</td></tr></table><span id='postcolor'>
I'm planning on checking all the bolts and stuff pretty frequently at first to make sure they're holding up. &nbsp;If worse, comes to worse, I could always safety wire 'em...or tack weld 'em <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> .
LanceS13 is offline
Old 08-30-2002, 11:27 AM   #21
boosteds14
boosteds14's Avatar
well u dont really want to do a tack weld but safety wire is your best bet
240SXONE
Old 08-30-2002, 12:10 PM   #22
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
Lance,
The injectors, I say start bigger. The stock fuel rail should be able to support up to about 550cc injectors. Any after market injector for a SR will drop right in to the KA rail, unless otherwise specified. I am upgrading to a set of 480cc injectors out of an s15 SR.
From the looks of it you are building a motor that should hold well over 300hp. There is no reason to start with injectors that small.
-Matt
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline
Old 09-02-2002, 10:00 PM   #23
LanceS13
AutoX Junkie
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (uuninja @ Aug. 30 2002,1:10)</td></tr><tr><td id="QUOTE">Lance,
-Matt</td></tr></table><span id='postcolor'>
Well, in that case, I probably will go larger. &nbsp;I was under the impression that the biggest that the stock rail could take is 370cc injectors.
Since I was going with 300zx injectors from a parts store, where might I find larger ones?
LanceS13 is offline
Old 09-03-2002, 01:15 PM   #24
240racer
240racer's Avatar
240racer is an unknown quantity at this point
Definatly get the Walbro High pressure pump (FPN006 - $110)from http://www.autoperformanceengineerin.../fuelpump.html
Then go to http://heavythrottle.com or http://srswap.com/injectors.htm and buy some injectors that drop into your rail.
Safety wire anything you are nervous about backing out. &nbsp;
Good Luck, have fun with your setup
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline
Old 09-03-2002, 09:16 PM   #25
LanceS13
AutoX Junkie
Oh yeah, almost forgot.
What about spark plugs? &nbsp;Any suggestions?
LanceS13 is offline
Old 09-04-2002, 01:28 PM   #26
boosteds14
boosteds14's Avatar
umm, ill get back to u on spark plugs tomorrow. ill go home and check what i have. i forgot.
i know that i have two sets. one for under 18psi and another for over 18psi
240SXONE
Old 09-11-2002, 12:53 PM   #27
LanceS13
AutoX Junkie
Anymore comments, suggestions, questions?
Moving to FAQ.
When I get done with this (which may take a while), I'll include the exact parts list. &nbsp;Hopefully, I'll have pictures and maybe even a detailed procedure as well.
Thanks All!
LanceS13 is offline
Old 09-13-2002, 09:35 PM   #28
Kreator
Kreator's Avatar
Eh... MSD 6AL maybe? Kinda weird noone mentioned it &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'>
Kreator is offline
Old 11-13-2002, 01:16 PM   #29
Killer Kane
Killer Kane is an unknown quantity at this point
I have read a lot about turbo setups with DSM's in the last few years and one of the most important things I've learned is that your supporting mods will determine how much power you get from your turbo.
With that said, I would say go for the bigger injectors (my 14B turbo'd Eclipse has 450cc injectors for 190hp stock), Walbro 255 fuel pump, A'pexi AFC, and decent intercooler for your rather large turbo. &nbsp;You can always find used intercooler setups, albeit with the wrong piping (might be able to use some of it) at www.dsmtrader.com. &nbsp;Besides FMIC's, look for Supra MkIV sidemounts, they are great at exactly the hp ranges for which you are looking.
'90 Eclipse GS-T
Killer Kane is offline
