#35 |
So Brian, are you guys going to come up with a new way to connect the reservoir to the lines? I mean it uses a hose you just push over the PS line and clamp done. To me if you're going to upgrade the pump line, shouldnt we upgrade the reservoir line? Im thinking of welding on a -6AN to the reservoir and then cut, slip on a -6AN & flair the lower PS line and use a -6AN line similar to the one you're using. You think this is overkill? I really really HATE LEAKS!!
Scott |
#36 |
![]() Join Date: Feb 2004
ill have these til i sell out ... then i will order material to make more. We still have a good amount left though.
as for making a low pressure side of AN fittings.... to do it RIGHT you would have to weld an AN onto the pump, weld AN onto both ports on the reeveoir, and use AN adaptor in rack. It would be easier to make a custom resevoir in that case or use one from Canton. I think its kinda overkill if you have nice hose to begin with but NOT nessecarily a bad idea at all.... it would just end up being pretty pricey. |
#37 |
![]() Join Date: May 2002
brian
can u let me know which AN item ineed for the LP side on the rack? imma do exactly what u said above on mine this week do u know whicho ne i need? earls is down the freeway thanks! |
#47 |
If you have a RHD car then youd need a custom line. We can make one no problem pre-assembled and ready to. Shoot me an email if your interested.
#52 |
I'm interested in the "new" batch.
I would request for round 2 either black braided hose or steel braided hose.
jollydwarf.com |
#53 | |
Yes we still have a bunch in stock. Quote:
We astill have some of the first batch. the second batch will most likely be the same thing as i see no reason to revise it as of now. Earls only makes PS hose in Blue so that is the only color we will have. If you wanted a black one you could always use some black wire loom over it to cover the blue. |
#54 |
![]() Join Date: Mar 2004
What is the problem with the OEM hose?... It blows from too much counter steering or something?... Or maybe from running large tires up front?...
http://respectvolkracing.blogspot.com/ |
#55 | |
Brian, maybe for the ballin customers you can offer BRMS lines for the PS hose ![]() Scott |
#57 | |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
I'll probably order mine on Monday because my lower PS line leaks as well and paying for a brand new one from Nissan is out of the question.
Forums: www.houston-imports.com<Car Talk Moderator www.nissaninfiniticlub.net www.240sxforums.com www.zilvia.net http://speedelements.net |
#58 |
Just bought mine over the phone. Can't wait to get it in!
