Old 10-07-2007, 09:05 AM   #121
CursedGTR
CursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfection
For the Past week I have been working on my subframe and Crossmember. A complete PITA with little or no return other than aesthetic. However, After Using a Combination of PAint Stripper (The same stuff I used to strip my car) to remove paint, Pain thiner to clean and Naval Jelly to remove rust with a Die Grinder and wire wheel attachment I was able to finally get them read to go. This is what the subframe looked like as I started.
I decided to play around with some silver paint that I picked up at the hardware store and paint the crossmember with it as kind of a base coat before I put the permanent color on there. I also painted the subframe with it but had to remove it to fix little imperfections in my prep work that were irritating me.
Once this was complete a friend of mine laid a nice coat of metallic purple that he mixed up followed by another coat and a few coats of clear. I thought the results were nice.
I also got the suspension arms from NAMS (Nagisa Auto Motorsports) this week, which include Fender Braces, Front Lower Control Arms, Rear Lower Control Arms, Tension Rods, Traction Rods, Toe Rods, Rear Upper Control Arms. They are kinda blingy but they are also pretty high quality and should be just fine under the stresses of whatever kind of driving I am doing.
CursedGTR is offline
Old 10-07-2007, 09:41 AM   #122
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
i cant wait until this thing is done. freakin amazing.
ladiesman8527 is offline
Old 10-07-2007, 09:52 AM   #123
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
looks awsome man. keep up the great work
Nachtmensch is offline
Old 10-07-2007, 09:57 AM   #124
swpdwgn
swpdwgn's Avatar
swpdwgn is making a name for him/her selfswpdwgn is making a name for him/her selfswpdwgn is making a name for him/her self
Send a message via AIM to swpdwgn
the parts just keep flowing in like water... jesus..
lovin the flames on the motor. looks like you got the idea from c&y sports? they do that to alot of their jz motors and rb's
swpdwgn is offline
Old 10-07-2007, 09:58 AM   #125
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Did Scott powdercoat the subframe?
Buy my Stillway shifter!
Koopa Troopa is offline
Old 10-07-2007, 10:11 AM   #126
ThatGuy
Admin Asshole
ThatGuy's Avatar
Paint all the arms the same shade of purple. Make it look like you ran over Barney.
ThatGuy is offline
Old 10-07-2007, 11:42 AM   #127
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
Dam front lower control arms!
CKAMC is offline
Old 10-07-2007, 12:58 PM   #128
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
hahahaha I was thinking the same thing (minus the Barney bit ) You should paint the arms too.
Neejay is offline
Old 10-07-2007, 01:22 PM   #129
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
shiiiiiit, you make me so mad I didnt repaint all of my suspension parts and subframe in the x-million times I have had my LS1FC3S apart over the past 4 years wtf.
your project looks GREAT~!
more pics!
cannot wait to see the finished ride all shiny like new and ROMPING the gas in a tire shredding WOT pull!!!!!
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline
Old 10-07-2007, 05:23 PM   #130
CursedGTR
Nah, C&Y mainly uses solid colors that fade in and out, but they also use alot of sheet metal trim in their engine bays, which I do plan to do. The idea for the valve covers really came from a chopper. There was a bike show here a while back while I was building the motor and I really admired the attention to detail that was put into the bikes from construction on, so I decided to do the same thing, outlandish paint and alot of polished stuff. So far so Good.
C&Y has a shop down here in Okinawa now and I used to live right across the street from them, but since I have moved I only make it down there occasionally (When they have something for sale that I want or I hear of a different car that is cool). I have never seen them use flames though.
Old 10-07-2007, 07:57 PM   #131
yokotas13
yokotas13's Avatar
dude, paint the arms. do it
yokotas13 is offline
Old 10-07-2007, 08:06 PM   #132
90KAcoupe
90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future
Send a message via AIM to 90KAcoupe
cleaning the subframes are a PITA!!!!! when i cleaned mine to paint it, it had a bunch of the rubberized undercoating... i scrubbed on that think for like 3 days. the only thing that would take the undercoating off was gas. but nice build man!!!!!!!
90KAcoupe is offline
Old 10-07-2007, 08:45 PM   #133
G-Wagon
G-Wagon is an unknown quantity at this point
G-Wagon is offline
Old 10-07-2007, 08:55 PM   #134
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
wow....im usually not considered a jealous type person but..... o wait....yeah i am.... i HATE YOU! lol....keep it up this shit is better than surfing for p0rn
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline
Old 10-07-2007, 10:24 PM   #135
fueled by hate
fueled by hate is making a name for him/her selffueled by hate is making a name for him/her selffueled by hate is making a name for him/her self
Just curious, what brand of tools and tool boxes are popular in Japan. Saw a few boxes in the backround and didn't recognize anything.
fueled by hate is offline
Old 10-07-2007, 11:15 PM   #136
jrocslider
jrocslider's Avatar
jrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfection
suscribed. this thread excites me.
jrocslider is offline
Old 10-07-2007, 11:37 PM   #137
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
painted arms=chipped paint eventually.. Esp. on lowers
gotta240 is offline
Old 10-08-2007, 12:28 AM   #138
CursedGTR
No, we painted them up there at Hansen with regular old automotive paint.
Old 10-08-2007, 12:29 AM   #139
CursedGTR
You are correct and that is why these things will remain chrome. Most likely will throw a coat of some hardcore protectant (clear) on there but that is about it.
Old 10-08-2007, 12:39 AM   #140
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
this car is going to be amazing when its done.. keep up the good work..
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline
Old 10-08-2007, 01:21 AM   #141
TonKpilS14
TonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymoreTonKpilS14 is not welcome here anymore
Send a message via AIM to TonKpilS14
Do you own a shop or r u just balln'
what do u do for a living ... god damn
thats some serious cash.
TonKpilS14 is offline
Old 10-08-2007, 04:19 AM   #142
CursedGTR
I do all my work at a hobby shop. I just pay for the bay time there and since I bring my own welding supplies they usually do not charge me for anything since I even kick cash towards the gas bottles.
Ballin? Nah, not really, I save for and plan what the next step will be very carefully. I also sold my GTR in order to focus on this project which saved me a metric shit ton of cash. I am a Marine but I do some stuff on the side here and there as well in order to fund the habit.
Old 10-08-2007, 05:08 AM   #143
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
hurry up man!!! i wanna see it finished!!! +100000 beautiful work
your neg reps match my avitar.... keep em commin
drifting_changed_mylife is offline
Old 10-08-2007, 05:55 AM   #144
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
awesome, thanks for the updates.
IIIXziuR is offline
Old 10-08-2007, 07:45 AM   #145
axiomatik
axiomatik's Avatar
sounds like a man-whore. Your build keeps getting better. nice work.
axiomatik is offline
Old 10-08-2007, 09:18 AM   #146
illvialuver
illvialuver's Avatar
lookin good , keep up the god work, and that is exactly how i painted my tool box and alve cover.
illvialuver is offline
Old 10-13-2007, 06:06 AM   #147
CursedGTR
Finished up some more work today. The car is getting masked off right now in preparation for the next stage in the paint work. Meanwhile, I painted the diff pumpkin and polished the diff cover, got the subframe bushings put into the subframe and modified the bumper with two Billion Carbon ducts just to get some extra air flow through the intercooler and to add a touch of originality. Pics Below as usual.
Old 10-13-2007, 07:59 AM   #148
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
Awesome as usual sir. I'm loving the purple S-Frame and the polished pieces. That thing is gonna look money under there. Keep it up!
IIIXziuR is offline
Old 10-13-2007, 11:16 AM   #149
Rasty180SX
Rasty180SX's Avatar
Rasty180SX is an unknown quantity at this point
Send a message via AIM to Rasty180SX
Clean job on the ducts....I like that!!!
Rasty180SX is offline
Old 10-13-2007, 11:37 AM   #150
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
damn
msglngth
Review Thread
bardabe is offline
